From Boosted to... Boosted again! - My project
Old Jun 7, 2006 | 10:30 AM
rizen's Avatar
Default From Boosted to... Boosted again! - My project
Ok, so after the first setup I was making 308 WHP @ 6psi on stock internals.
It's time for the rebuild. I snapped a couple of pictures. With many more to come, stay tuned!
A taste of what is going in.
84MM CP Pistons
Darton mid kit
Oliver connecting rods
AEM EMS and much much more.
Old Jun 7, 2006 | 10:32 AM
Speed Infliction's Avatar
Default Re: From Boosted to... Boosted again! - My project (rizen)
what was your first setup and did you have any problems with the block without sleeves?
Old Jun 7, 2006 | 10:48 AM
rizen's Avatar
Default Re: From Boosted to... Boosted again! - My project (Black Mamba)
no problems with the block at all. I just want a little more power and reliability.
Old Jun 7, 2006 | 10:57 AM
Dave_B's Avatar
LMK if you need and hand in the rebuild process. Who's doing your machine work?
Old Jun 7, 2006 | 11:00 AM
infulleffect's Avatar
Default Re: (Dave_B)
nice after that FL trip it is nice to see this coming together
Old Jun 7, 2006 | 12:51 PM
kruthles's Avatar
Kieth your bay is filthy clean that **** up
good luck on the rebuild process
Old Jun 7, 2006 | 12:55 PM
JjuuN R's Avatar
Default Re: From Boosted to... Boosted again! - My project (kruthles)
daily updates please, you must have had a gem of a motor to make 310whp on 6psi
Old Jun 7, 2006 | 01:18 PM
coolhandluke's Avatar
Default Re: From Boosted to... Boosted again! - My project (JUN.R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN.R &raquo;</TD></TR><TR><TD CLASS="quote">daily updates please, you must have had a gem of a motor to make 310whp on 6psi </TD></TR></TABLE>
ditto!
Old Jun 7, 2006 | 02:37 PM
rizen's Avatar
It's a possibility! I had a good tuner, big turbo, and the EMS.
Old Jun 7, 2006 | 02:41 PM
rizen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">LMK if you need and hand in the rebuild process. Who's doing your machine work?</TD></TR></TABLE>
Thanks Dave.
MesaBalacing is doing the block. I believe they do the Titan Motorsports blocks as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kruthles &raquo;</TD></TR><TR><TD CLASS="quote">Kieth your bay is filthy clean that **** up
good luck on the rebuild process </TD></TR></TABLE>
You aint kidding! Simple green + Toothbrush will be in full effect!
Yea, probably. I'll def keep you guys up to date on the progress of this build. I'm trying to put it motion so I can be at the next Hype-R meet.
Old Jun 7, 2006 | 04:29 PM
JjuuN R's Avatar
guess you're not going to Expo this year eh? heh
Old Jun 7, 2006 | 06:16 PM
Lifter2012's Avatar
looks scary bro
Old Jun 7, 2006 | 07:00 PM
rizen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN.R &raquo;</TD></TR><TR><TD CLASS="quote">guess you're not going to Expo this year eh? heh</TD></TR></TABLE>
Na, not this year. Maybe next
Old Jun 7, 2006 | 07:41 PM
cambopheonix56's Avatar
looks good. keep us updated
Old Jun 8, 2006 | 12:29 AM
Haleiwa-Brando's Avatar
Default Re: From Boosted to... Boosted again! - My project (cambopheonix56)
How much boost daily driven are you going to run? 15?
If your interested, I have a near new set of Precision Injectors 1000cc low-impedence if you get the urge to boost more than 15lbs. I did
Old Jun 8, 2006 | 05:00 AM
nautica_t's Avatar
nice boost!!
well you got im from me ;P
Old Jun 8, 2006 | 05:18 AM
DontBlink's Avatar
Default Re: (nautica_t)
got some nice parts there
good luck with the build
Old Jun 8, 2006 | 06:46 AM
Jet Phi's Avatar
good luck man and keep us updated
Old Jun 8, 2006 | 07:58 AM
PrinceAli132's Avatar
Default Re: From Boosted to... Boosted again! - My project (Jet Phi)
Can't wait to see this done. Let me know if you need a hand with anything.
Ali
Old Jun 8, 2006 | 08:37 AM
rizen's Avatar
Default Re: From Boosted to... Boosted again! - My project (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">How much boost daily driven are you going to run? 15?
If your interested, I have a near new set of Precision Injectors 1000cc low-impedence if you get the urge to boost more than 15lbs. I did </TD></TR></TABLE>
Plan on anywhere between 15-17 psi daily =]
Wish I knew earlier you had the injectors, I got some already. Thanks though
Old Jun 8, 2006 | 07:04 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rizen &raquo;</TD></TR><TR><TD CLASS="quote">Ok, so after the first setup I was making 308 WHP @ 6psi on stock internals.
i need time slips to believe anywhere close to those numbers......
i don't care how much timing you have in the engine you are not making 128hp over stock itr on a good day or 21.1x hp per pound of boost!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jun 8, 2006 | 07:12 PM
Casey's Avatar
Default Re: From Boosted to... Boosted again! - My project (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">
i don't care how much timing you have in the engine you are not making 128hp over stock itr on a good day or 21.1x hp per pound of boost!!!!!!!!!!!!!!!!!!!!!!!!!!!!!</TD></TR></TABLE>
all you do is hate
i believe you. i flew out to cali and dyno'd on churches dyno. I made 317/310 on my d15b with the jrsc kit. i was running 6 psi, well more like 6.6 but still.
Old Jun 8, 2006 | 07:24 PM
chad's Avatar
Moderator
Default Re: From Boosted to... Boosted again! - My project (Casey)
all you do is hate
:cough: :cough: headgasket :cough: :cough: do i need to say anything else??
Old Jun 8, 2006 | 07:25 PM
Casey's Avatar
have you got somethin in your throat?
dont hate i was trying to up my compression by flipping it yo.
do i need to tell all your itr friends what you say about them behind their backs?
Old Jun 8, 2006 | 07:29 PM
chad's Avatar
Moderator
do i need to tell all your itr friends what you say about them behind their backs? </TD></TR></TABLE>
so tomorrow labor rate is gonna be......
maybe you should have somebody who knows what they are doing work on your car instead of you looking at it...and thinking "YOOOOOOOOOOOOOUUUU CAN DOOOOOOOOOOOOOOOO EAT......hmmmm.....
