brake pedal sinking to the floor at stoplights, but my fluid level does not change?
Old Jun 7, 2006 | 10:01 AM
92integraVTECgsr's Avatar
Default brake pedal sinking to the floor at stoplights, but my fluid level does not change?
My brake pedal sinks to the floor when I'm at stop lights. I'm not leaking any brake fluid because the level in the MC is always at the top.
Would my MC still be bad? or is it my Brake Booster? or could it just be I need to keep bleeding my MC a lot more?
thanks.
Old Jun 7, 2006 | 10:17 AM
Circuit Star-29's Avatar
Default Re: brake pedal sinking to the floor at stoplights, but my fluid level does not change? (92integraVT
A search would reveal a number of topics just discussed on the same issue.
Old Jun 7, 2006 | 11:01 AM
gurgle's Avatar
https://honda-tech.com/zerothread/1608381
It's called an internal bypass. Fluid is going around your worn out MC piston seals and back into the reservoir. Happens all the time.
Old Jun 7, 2006 | 11:10 AM
__oversea's Avatar
you can do leak test.
i dont wanna read my helm manual now
Old Jun 7, 2006 | 02:08 PM
jerdizzle14's Avatar
if your fluid idnt changing i would just keep trying to bleed your brakes bro when was the last time you switched your pads and rotors
Old Jun 7, 2006 | 02:18 PM
new PBR Metal Master Pads, New Duralast Rotors, New SS Goodridge Lines
Old Jun 7, 2006 | 02:57 PM
THE LORD OF CHAOS's Avatar
your brake master cylinder's internal seals are shot. replace it with a new one, dont bother getting a reman one they are junk.
trust me i know. the same thing happened to me and i went through 3 remans before i got one that worked.
make sure you bench bleed the new mc properly before you hook it up and then bleed the brakes again to make sure that all the air is out of the lines.
Andyxramirez
Mar 11, 2013 05:56 PM
jtrig
May 30, 2011 08:48 PM
namewasdallas
Suspension & Brakes
Apr 6, 2010 08:06 PM
96_hatch
May 1, 2003 09:34 AM
Flux
Jul 14, 2002 09:57 PM
