Dumbass question of the day.
Okay, for starters, d16z6 block stock pistons, stock head, b16 rods, what kind of compression ratio could this produce? I know it can be done and should give lower compression, but how much lower?
thanks
thanks
i would like to see how you do that.
oh when you're done, can i one of those setup too.
i bet the compression ratio is so low that it goes into negative numbers.
[Modified by sshaikh01, 1:00 AM 4/16/2002]
Okay, i hated to ask that question, because i knew I would get labeled an idiot newbie for sure. But anyway, the guy that is building the motor thinks he heard that they can be used, but i don't know.
Oh btw, we're not using the dohc head, just the cam, doh! I don't even know how that came across like that.
uhh...your using a B16 Cam on your SOHC???
this thread keeps getting better every minute!
The DX Rex
Feb 22, 2005 09:02 PM
