fuel pump problems/ wiring
ok i have had this problem ever since the new interior harness has gone in. i have a 89 crx with a 91 crx both dx harnesses. the problem is the fuel pump will not power. i know its not the pump itsekf because i can give the line power and it works great. if i cant get the ecu wiring down or anything would it be ok to t it off with another wire from the ecu so it comes on with the car or should i wit till i fond out this crap? thanks and i checked the relay so that isn't the prob. thanks for anything i get.
how would thet make it not work? the filter falling off has nothing to do with power does it? i checked the fuse its good still. damn im running out of stuff to do to fix it. thats either good or bad. i really dont know
ok it clicks like it should once whene the key is turned and once about 2 seconds after. does this mean anything. i also checked the voltage coming out of every wire. most of them read 8.xx but the ground and another wire were at 0.00 what does this mean?
Projekt CR-X
Sep 21, 2010 06:38 PM
