O2 Oxygen Sensor Wiring
Old Jun 6, 2006 | 11:45 PM
KillerBee18's Avatar
Default O2 Oxygen Sensor Wiring
OK so here the situation i have a obd 1 to obd 2 (1996) harness and i cut the lambada 1 ( o2 input ) so i could run my wideband o2 to my AEM EMS. I am now trying to go back to the stock ecu for emission testing but i dont know which pin out it is on the OBD 2 side the wire that was cut on the OBD 1 side was pin D14 i need to know which pin it goes to on the OBD 2 side. Also i need to know which of the two connectors on the engine harness is for the primary o2 sensor since OBD1 ecu dont use secondary ones.
Thanks
t-del28
14
Feb 28, 2013 06:43 PM
adamdecimals
Apr 1, 2010 01:05 PM
jdm1980
Mar 10, 2008 08:13 AM
russianswty
Dec 29, 2006 04:30 PM
KimChiKid
Oct 8, 2003 10:07 AM
