climate control
Old Jun 6, 2006 | 10:41 PM
supracrx's Avatar
Default climate control
im in the process of trying to fix the damn temp control on the climate control. .im not sure is it the cable or wat. but i can take off the center console but having hard time with taking the entire climate control out. the metal brackets holding it....i cant get it to fit between the two...do i force it out..or does it slide out from the back or wat? help please.....also do i have to disconnect the glove box to get to cables or no?
Old Jun 6, 2006 | 11:17 PM
project 2two9's Avatar
Default Re: climate control (supracrx)
u might have to take off the whole center console assembly... because the console covers some screws
Old Jun 7, 2006 | 07:51 PM
supracrx's Avatar
which center console? the black surrounding the raido is off....i just gotta take it out of the metal bracket...i got all the screws out...
Old Jun 8, 2006 | 12:10 AM
supracrx's Avatar
help anyone? do i jus tkinda bend the metal bracket out of the way to slide it out a bit to be able to disconnect those cables?
Old Jun 8, 2006 | 04:25 AM
crex23's Avatar
Default Re: (supracrx)
You'll have to take out the center console, the climate control is screwed into the metal frame beneath the console, and you'll have to snake your arm in under the dash and from behind to unplug the harness connectors (I did on mine). GL
Old Jun 8, 2006 | 04:38 AM
CRX Toad's Avatar
Supracrx, click on the "PLATES" in my signature and there is a write up that shows you what you need to do.
Old Jun 8, 2006 | 06:48 AM
supracrx's Avatar
hey nice write up...exactly what i needed...
is the 88 the same way?
farfrumugen
Jan 31, 2011 08:03 PM
Adrian SI
May 31, 2007 06:13 PM
Tippyman
10
Jul 30, 2006 09:09 PM
MattGSR
Aug 20, 2003 11:37 AM
silverintegra9
Mar 25, 2003 09:21 PM
