newbie to the ludes. need help plz
Ok well i just came back from the dealer and i was jus lookin at the cars. same as last time i went lookin, i ended up trading in my 97eclipse for a 04solara. dnt ask why. but i saw a 01 Lude type sh. I went on kbb.com and for that yr they only show 2 options. coupe 2dr and type sh coupe 2dr, what is the diff between both cars? i looked under the hood and it comes with a h22a2, if i member correctly. so if someone can help. and no sorry i didnt do a search cuz its late and i gotta get some sleep for work tomorrow, so any info would be helpful. power diff? or wat it is dat diff. Thanks! peace!
type sh has atts, different cams ( +5 hp i think) is slightly lower, and comes with 16" 5-spoke wheels. it is also heavier than the base model due to the atts system
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shutupnskate »</TD></TR><TR><TD CLASS="quote">type sh has atts, different cams ( +5 hp i think) is slightly lower, and comes with 16" 5-spoke wheels. it is also heavier than the base model due to the atts system</TD></TR></TABLE>
Wrong... (except for the atts and 16" 5 spoke wheels)
Same power, same cams, same ride height. The sh is not even 100lbs heavier sh = 3042lbs, base = 2954lbs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6Driver »</TD></TR><TR><TD CLASS="quote">
This is correct.
I hate it when people talk about the myth of the cam difference in HP terms. The cams might be physically (haven't confirmed) different but it doesn't yeild more HP.
This is correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Behan »</TD></TR><TR><TD CLASS="quote">
ATTS: Active Torque Transfer System.
It basically sends more power to the outside wheel when cornering making it spin 15% faster than the inside wheel.</TD></TR></TABLE>
It is not compatable with LSD trans swap but cant handle more than 250ish hp so you would need to remove it anyway if you were doing a nice build. Like 4th gens 4WS system there are people that have problems with it throwing codes but people still stand by its effectiveness.
FadedEpic
Aug 27, 2004 12:53 AM
