Prelude Injectors (again).....
Old Apr 15, 2002 | 01:28 PM
Black R's Avatar
25 Year Member
Default Prelude Injectors (again).....
Suppose you are running stock (240cc/min) injectors at 50psi and replace them with prelude (290cc/min) injectors... What psi would you run at to compensate?
I'm guessing that b/c they are ~21% bigger than stock itr injectors, you'll lower fuel pressure by 21%.....?
So instead of running 50psi, you could run 39.5psi when going from 240's to 290's?
Old Apr 15, 2002 | 01:36 PM
non-VTEC's Avatar
Default Re: Prelude Injectors (again)..... (Black R)
run them at the stock Prelude VTEC fuel pressure setting.......which i belive is about 40psi with the vacum hose connected tot he FPR.....
Old Jun 5, 2003 | 06:23 AM
paulITR's Avatar
Default Re: Prelude Injectors (non-VTEC)
a bump for an answer to an interesting question
Old Jun 5, 2003 | 07:28 AM
VTHokie's Avatar
I have 97+ prelude injectors in my car right now, and yack just tuned them using the vafc. I'm still at stock ITR pressure. Beotch is leaned out like crazy though.
B18CXr's Avatar
do the job correctly and get some form of electronic fuel control, when you begin to lower fuel pressure the spray pattern suffers
IMHO
Old Jun 5, 2003 | 08:30 AM
Asahi's Avatar
Default Re: Prelude Injectors (B18CXr)
Good info jack
Old Jun 5, 2003 | 10:04 AM
sgT's Avatar
sgT
It will be about 35psi off vacuum. Possibly too low to spray well, but might work.
Integra99
May 31, 2005 05:25 PM
Civichatch27
Apr 22, 2005 02:01 PM
Boosted 01 SH
Mar 13, 2005 06:21 AM
fredtoast
May 4, 2003 02:00 PM
dry-ice
Nov 8, 2002 03:33 PM
