b-swap in CRX help im lost
Old Jun 6, 2006 | 08:22 PM
memorybox's Avatar
Default b-swap in CRX help im lost
Ok I searched but I keep getting confused. I am buying a 90 CRX with the dual point injection. I want to swap in a b16a. I searched to see what all needed to be done and had a couple of questions
Will my front hubs need to be changed or is that on the 80's models
is my car obd0 or how much wiring problem will i run into ( just plug up the b16a harness to my car? or will i have to make the plugs and change ecus?)
can i change to a hydro clutch with the b16 tranny or am i stuck with a cable clutch
Old Jun 6, 2006 | 08:52 PM
crxnj's Avatar
Default Re: b-swap in CRX help im lost (memorybox)
as long as you dont have an hf the stock hubs will work fine..your car is obd0 92-95 is obd1 and 96+ is obd2a/b..no the b16 harness wont just plug up and i dont suggest using it ,,(well only for parts)....if this is an obd0 b16 swap its pretty straigt foward with wiring,,do mpfi conversion and add the 4 wires for vtec..what year b16 swap are you getting?
Old Jun 6, 2006 | 09:10 PM
Burlyirishdude's Avatar
Default Re: b-swap in CRX help im lost (Mr.speaker)
Well if it's dual port....it won't be an hf. But there's the possibility of someone trying to run a dx motor with an hf tranny. anyway before confusion.
The b16a obd-0 is believe it or not is ALMOST a straight hookup...
Just make you standard dpfi-mpfi conversion. If you don't know what to do, search rywire.com. those guys will make it as easy as plug n play.
You'll need:
ecu pw0 or pr3
One knock sensor
one oil pressure wire/with one ground
vtec sensor
and two o2 sensors.
The hubs on a dx will fit the axles that come with the axels that fit a b-series tranny diff.
Your car is obd-0. 1st gen b16 is obd-0. 2nd gen are obd-1. Obd-0=milky white plugs like in your car now. obd-1 has grey plugs.
Easy-stay obd-0 and just add the sensros i mentioned above
more taxing- go obd-1. change injectors, distributor, add wires. But it makes it easier and better for tunning.
Hasport does make a hydro-cable clutch kit. I love cable but if you want hydro get the s80 tranny. ITR tranny with lsd. If you decide to stay cable. stick with the Ys-1 out of a 90-93 gs-r integ.
i know it sounds like a mess....but just search and do some troubleshooting and it'll come out *******!
Old Jun 7, 2006 | 08:30 PM
memorybox's Avatar
Default Re: b-swap in CRX help im lost (Burlyirishdude)
ok since mine has dual point injection is it the standard model with the 92 hp d15b? or do i have the 70hp motor?
the seller wasnt clear and told me he thought it was a dx, but there is no dx badge. i just no its a 90 model
Old Jun 7, 2006 | 08:40 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by memorybox &raquo;</TD></TR><TR><TD CLASS="quote">ok since mine has dual point injection is it the standard model with the 92 hp d15b? or do i have the 70hp motor?
the seller wasnt clear and told me he thought it was a dx, but there is no dx badge. i just no its a 90 model </TD></TR></TABLE>
yeah its most likely a dx unless the person swapped dual point into a hf (very doubtfull) and you got the 92 hp d15b2..dx doesnt have a rear badge like hf or si so its perfectly normal
90AWDeclipse
22
Feb 21, 2010 02:49 PM
89crxSIRI
Nov 3, 2008 06:30 AM
folta2169
18
Dec 14, 2004 06:35 PM
Daneish
Apr 4, 2004 06:42 AM
IwantAswap
Feb 16, 2004 11:44 AM
