dx harness, speedo clip?
Old Jun 6, 2006 | 07:11 PM
philkehn's Avatar
Default dx harness, speedo clip?
Does a dx harness have a speedo clip (clip that tells your guages how fast your going) that plugs into a b16a or did the dx have another method of telling it and if so how do i get my speedometer to work on my b16 with a dx harness
Old Jun 6, 2006 | 07:13 PM
exsinnovation's Avatar
the speedo uses a cable that is seperate from your harness to tell your how fast ur going. if your B series ten you need to wire in a VSS
Old Jun 6, 2006 | 07:17 PM
philkehn's Avatar
is the cable that the 88 dx uses come from the fire wall has a boot sticking out and a metal tip? if it is thats my problem, do you know what wires or even what pins at the ecu i would have to wire the vss to?
Old Jun 6, 2006 | 07:18 PM
Umm im not sure but you can use the search
Old Jun 6, 2006 | 07:19 PM
philkehn's Avatar
will do thanks for the help you had
Old Jun 6, 2006 | 07:53 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (philkehn)
It sounds like you may have the wrong sending unit
on the transmission.
Some are electric and some are cable driven.
The cable driven unit looks like this:
I have heard of people using the D-series unit in the B trans.
Old Jun 6, 2006 | 08:06 PM
philkehn's Avatar
yep thats what it is i have cable i need electric is there anyway you can wire up a cable to a electric or do i have to get the whole unit?
Old Jun 13, 2006 | 12:15 PM
philkehn's Avatar
anyone know how to do a cable speedo clip conversion to a vss clip
Old Jun 13, 2006 | 01:43 PM
Rywire's Avatar
elec vss? black wire is ground, black with yellow, 12v pos, and the 3rd wire taps the speed sensor at the cluster/ or at the ecu
Old Jun 13, 2006 | 08:47 PM
philkehn's Avatar
thanks do you know what pin it connects to at the ecu? or even the color that comes out of the engine harness or the gauges?
Old Jun 13, 2006 | 10:52 PM
Rywire's Avatar
its obd0 b16 (ecu position)
Old Jun 13, 2006 | 11:04 PM
philkehn's Avatar
Default Re: (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">its obd0 b16 (ecu position)</TD></TR></TABLE>
are you asking? lol, it is obd0
Old Jun 13, 2006 | 11:10 PM
pug B position 16
Old Jun 13, 2006 | 11:13 PM
philkehn's Avatar
oh lol i thought he meant b16 as the engine
Old Jun 14, 2006 | 10:45 AM
philkehn's Avatar
ok well im vcc elec clip has a yellow/white, yellow and black which is which?
Old Jun 14, 2006 | 11:09 AM
philkehn's Avatar
bump
Old Jun 14, 2006 | 09:25 PM
philkehn's Avatar
bump2
Old Jun 15, 2006 | 10:40 AM
philkehn's Avatar
well i got the wire coming from the ecu at b - 16 do i run that wire to the yellow or the the yellow white? and where should i ground the black and where should i run the power to
Old Jun 15, 2006 | 08:42 PM
philkehn's Avatar
Default Re: dx harness, speedo clip? (philkehn)
19993 x bump, i need help someone has to have done a cable to electric speedo i know someone can help
crxguy406
20
Feb 6, 2011 08:59 AM
masemac
Jan 13, 2011 12:57 PM
LSvtechatch97
Oct 15, 2004 04:30 AM
jdmDXrex
Mar 7, 2002 01:03 AM
