Gauges Illnumation
Old Jun 6, 2006 | 05:25 PM
97RSTEG's Avatar
Default Gauges Illnumation
I got 1996 honda civic dx hb auto and for some reason the instrument lights wont turn on when you turn on the headlights, all the gauges work it just the there not illnumated. I checked a number of fuses and there all fine what might be the problem?
Old Jun 6, 2006 | 05:29 PM
JDM-EJ1's Avatar
Default Re: Gauges Illnumation (Pederoski)
Does your climate control light up? Have you checked your bulbs in the cluster?
Old Jun 6, 2006 | 05:34 PM
97RSTEG's Avatar
Default Re: Gauges Illnumation (JDM-EJ1)
for as long i have had the car the cilmate control never lit up and also is there an easy access to the bulbs to change them
Old Jun 6, 2006 | 05:38 PM
JDM-EJ1's Avatar
If your climate doesn't light up either, it's more than likely a fuse. Try checking them again. The only way to replace the bulbs in your cluster is to pull the thing out.
Old Jun 6, 2006 | 06:39 PM
Echo7847's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">If your climate doesn't light up either, it's more than likely a fuse. Try checking them again. The only way to replace the bulbs in your cluster is to pull the thing out.</TD></TR></TABLE>
Check your dimmer switch as well.
Old Jun 6, 2006 | 06:40 PM
JDM-EJ1's Avatar
Default Re: Gauges Illnumation (Echo7847)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 &raquo;</TD></TR><TR><TD CLASS="quote">
Check your dimmer switch as well.</TD></TR></TABLE>
To'che. I forgot about this. This also needs to be functioning correctly for your gauges to work.
Civic--mini me
10
Apr 14, 2014 06:23 AM
king29
Dec 4, 2008 03:21 PM
. a d a m
50
Aug 12, 2007 01:45 PM
ecksman
Nov 6, 2006 08:38 PM
tuyettam
Mar 31, 2006 02:56 PM
