car idles low then dies
Old Jun 6, 2006 | 01:37 PM
89sicivic's Avatar
Default car idles low then dies
well after getting my 90 dx for 600 bucks it starting to act up...the problem is when i come up to a stop light the rpm drops below 1 then sometimes it shoots back up to around 1 then sometimes it just dies...any idea on what it could be the lights dont dim so its not the alternator...
Old Jun 6, 2006 | 01:39 PM
temp's Avatar
Default Re: car idles low then dies (89sicivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89sicivic &raquo;</TD></TR><TR><TD CLASS="quote">well after getting my 90 dx for 600 bucks it starting to act up...the problem is when i come up to a stop light the rpm drops below 1 then sometimes it shoots back up to around 1 then sometimes it just dies...any idea on what it could be the lights dont dim so its not the alternator...</TD></TR></TABLE>
whats your timing set at
Old Jun 6, 2006 | 01:45 PM
89sicivic's Avatar
timing isn't retarded or advanced everything is stock besides some bolt ons
Old Jun 6, 2006 | 01:47 PM
temp's Avatar
Default Re: (89sicivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89sicivic &raquo;</TD></TR><TR><TD CLASS="quote">timing isn't retarded or advanced everything is stock besides some bolt ons</TD></TR></TABLE>
i didnt ask that, i asked what your timing is set at.
Old Jun 6, 2006 | 01:48 PM
89sicivic's Avatar
Old Jun 6, 2006 | 01:49 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89sicivic &raquo;</TD></TR><TR><TD CLASS="quote">0</TD></TR></TABLE>
are you ******* kidding me? how many degrees is your timing set at
Old Jun 6, 2006 | 01:55 PM
89sicivic's Avatar
oops the 0 was a accident my computer messed up....im not sure on what the timing is set at...im pretty sure it has nothin to do w/ timing cause other then this the cars fine idles right where its suppose to and no problems besides this idling problem which only happens everyonce in a while
Old Jun 6, 2006 | 01:56 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89sicivic &raquo;</TD></TR><TR><TD CLASS="quote">oops the 0 was a accident my computer messed up....im not sure on what the timing is set at...im pretty sure it has nothin to do w/ timing cause other then this the cars fine idles right where its suppose to and no problems besides this idling problem which only happens everyonce in a while</TD></TR></TABLE>
dude. go check your timing. just go check it.
Old Jun 6, 2006 | 01:58 PM
89sicivic's Avatar
alright will do that after work...meanwhile any other inputs....the car does have a adjustable cam gear put on by the owner b4 me
Old Jun 6, 2006 | 02:02 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89sicivic &raquo;</TD></TR><TR><TD CLASS="quote">alright will do that after work...meanwhile any other inputs....the car does have a adjustable cam gear put on by the owner b4 me</TD></TR></TABLE>
check timing, make sure timing is set to stock, then set cam gear to 0.
Old Jun 6, 2006 | 03:58 PM
89sicivic's Avatar
timing is set to stock cam gear at 0....
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89sicivic &raquo;</TD></TR><TR><TD CLASS="quote">timing is set to stock cam gear at 0....</TD></TR></TABLE>
what is the timing set at?
Old Jun 6, 2006 | 04:57 PM
89sicivic's Avatar
how about we get off the timing subject cause its not that problem....any others out there have any input
Old Jun 6, 2006 | 04:58 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89sicivic &raquo;</TD></TR><TR><TD CLASS="quote">how about we get off the timing subject cause its not that problem....any others out there have any input</TD></TR></TABLE>
how about you answer the question because it VERY WELL could be your problem. if you dont want help, dont ******* post.
Old Jun 6, 2006 | 05:35 PM
I Like Hondas's Avatar
ROFL!
Old Jun 6, 2006 | 05:58 PM
kkk69's Avatar
Default Re: (I Like Hondas)
lmao he dosnt know wht he is doin and knows nuthin bout timin u ****** idiot
Old Jun 6, 2006 | 06:03 PM
temp's Avatar
Default Re: (kkk69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kkk69 &raquo;</TD></TR><TR><TD CLASS="quote">lmao he dosnt know wht he is doin and knows nuthin bout timin u ****** idiot</TD></TR></TABLE>
06ers just keep getting better and better dont they. /yourself.
Old Jun 6, 2006 | 07:12 PM
89sicivic's Avatar
Default Re: (temp)
i would think that if it was timing the problem would happpen everytime i drove the car but it only happens at random times not all the time....i dont know what degree stock timing is suppose to be set at...and also you say if i dont want dont ******* post come on just cause i asked for other opinions on this matter dont mean you have to go saying **** like that i believe this is a open forum which means others are more then welcome to put there input in on matters as well and doesn't mean your answer is right
Old Jun 6, 2006 | 07:14 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89sicivic &raquo;</TD></TR><TR><TD CLASS="quote">i would think that if it was timing the problem would happpen everytime i drove the car but it only happens at random times not all the time....i dont know what degree stock timing is suppose to be set at...and also you say if i dont want dont ******* post come on just cause i asked for other opinions on this matter dont mean you have to go saying **** like that i believe this is a open forum which means others are more then welcome to put there input in on matters as well and doesn't mean your answer is right</TD></TR></TABLE>
dude, i am telling you CHECK YOUR TIMING FOR A REASON. you are coming here for HELP, you just admitted you dont know **** about timing. have someone check your timing for you. it should be set between 14-18 BTDC. if its not, there is your problem. just because its "random" does not mean its not a timing problem. check your damn timing already.
Old Jun 6, 2006 | 07:15 PM
philkehn's Avatar
check your throttle position sensor make sure its plugged in all the way other then that i have the same problem with the low idle my car however doesnt die... he is very right however it can easily be your timing, but if you think not check the tps and the eacv
exsinnovation's Avatar
ok well ill support his opinion check ur timing
Old Jun 6, 2006 | 07:16 PM
temp = HT dick hahaha
temp's Avatar
Default Re: (exsinnovation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exsinnovation &raquo;</TD></TR><TR><TD CLASS="quote">ok well ill support his opinion check ur timing</TD></TR></TABLE>
ty, now i demand nudes of your avitar girl .
after you have checked your timing, post pix of your plugs.
Old Jun 6, 2006 | 07:17 PM
sorry she doesnt do nudes. but LACIE HEART DOES.
Old Jun 6, 2006 | 07:18 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exsinnovation &raquo;</TD></TR><TR><TD CLASS="quote">sorry she doesnt do nudes. but LACIE HEART DOES.</TD></TR></TABLE>
bu...bu...bu...but i want nudes of the girl in your avitar
