FS: 2001 Type R transmission gears
Old Jun 6, 2006 | 01:26 PM
L'motaHB's Avatar
Default FS: 2001 Type R transmission gears
OBO
1st Gear - 3.230
3rd Gear - 1.458
4th Gear - 1.034
5th Gear - 0.787
Located in Southern California
Modified by L'motaHB at 3:31 PM 1/12/2008
Old Jun 7, 2006 | 07:50 AM
L'motaHB's Avatar
Default Re: FS: 2001 Type R transmission gears (L'motaHB)
wed
Old Jun 8, 2006 | 02:03 AM
L'motaHB's Avatar
thu
Old Jun 8, 2006 | 03:33 AM
ebpEM1_DJ's Avatar
tell me wat u want for em.... i dont wanna guess
Old Jun 8, 2006 | 03:37 AM
Bense's Avatar
is this a complete gear stack with all the syncros/hubs/sliders?
or did you have a jdm itr and get close ratio ats / infinitude gears?
Old Jun 8, 2006 | 11:56 AM
L'motaHB's Avatar
Default Re: FS: 2001 Type R transmission gears (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">is this a complete gear stack with all the syncros/hubs/sliders?
or did you have a jdm itr and get close ratio ats / infinitude gears?</TD></TR></TABLE>
Gears came out of the trans due to the install of ats gears. With that said I believe its just the gears itself, i'll take a closer look and try to get some pics up aswell.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebpEM1_DJ &raquo;</TD></TR><TR><TD CLASS="quote">tell me wat u want for em.... i dont wanna guess </TD></TR></TABLE> same here, i'd ball park around 350 - 400 just to get the ball rollin.
Old Jun 9, 2006 | 10:36 AM
L'motaHB's Avatar
FRIDAY
Old Jun 9, 2006 | 05:20 PM
L'motaHB's Avatar
Old Jun 11, 2006 | 12:04 PM
L'motaHB's Avatar
Old Jun 11, 2006 | 12:54 PM
Bense's Avatar
so, was it a 4.785 jdm itr transmission? Did you get the 3.077 1st gear installed with your ats set?
Old Jun 11, 2006 | 01:58 PM
L'motaHB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">so, was it a 4.785 jdm itr transmission? Did you get the 3.077 1st gear installed with your ats set?</TD></TR></TABLE>
no, got the 4.40 final drive. yes i on the first gear.
Old Jun 12, 2006 | 11:21 AM
L'motaHB's Avatar
Old Jun 13, 2006 | 01:03 PM
L'motaHB's Avatar
Old Jun 13, 2006 | 09:21 PM
L'motaHB's Avatar
Old Jun 13, 2006 | 09:31 PM
Bense's Avatar
free bump because if i had a ls or gsr trans, i'd want a 1.458 and 1.107 3rd & 4th gears
Old Jun 13, 2006 | 10:51 PM
JohnnieChimpo's Avatar
PMed
Bump because I need a 3rd gear from a B16 trans.
USDM ITR transmissions and CTR transmissions are B16 ratios w/LSDs.
Only the 98+ JDM ITR trans had the wide ratios and valued axle ratio .
http://www.allmotorhonda.com/t...s.htm
Old Jun 14, 2006 | 04:10 PM
L'motaHB's Avatar
Default Re: FS: 2001 Type R transmission gears (JohnnieChimpo)
asdfjkl;
Old Jun 15, 2006 | 04:32 PM
L'motaHB's Avatar
;lkjfdsa
Old Jun 18, 2006 | 01:24 PM
L'motaHB's Avatar
124567890
Old Jun 19, 2006 | 06:56 PM
L'motaHB's Avatar
Old Jun 21, 2006 | 11:54 AM
L'motaHB's Avatar
Old Jun 21, 2006 | 08:37 PM
L'motaHB's Avatar
Old Jun 22, 2006 | 09:12 PM
L'motaHB's Avatar
Old Jun 24, 2006 | 02:14 PM
L'motaHB's Avatar
10
Old Jun 26, 2006 | 11:26 AM
L'motaHB's Avatar
monday
