crx problems... any help - bogging/dying
ok so heres how it happens. when driving, in the first tenth of the gas pedals engagement, its generally pretty boggy. once i get past the bogs, and am at a higher rpm (2000+) you cant tell theres any problem. it will do this in each gear, and some times wont start. its only when the gas isnt being pushed down, like some times when i take turns and just engage the clutch, by the end of the turn when i am re-applying the gas, it bogs and struggles. ive seafoamed, no help. any clues?
Is the ecu spitting out any codes? When was the last time you changed your distributor cap, rotor, sparkplugs and plug wires, and fuel filter?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">whats your timing set at?
EDIT: seafoam is known to kill plugs.</TD></TR></TABLE>
very true. it also clogs up Cats with all that carbon being shot out at once....
d4rksid3
Feb 22, 2007 12:45 AM
