Gear shift stuck!
Old Jun 6, 2006 | 11:13 AM
jokers1's Avatar
Default Gear shift stuck!
In a 98 Accord. I put the key in, start the car, press the brake and put the car into gear. Yet the car will not go into gear. What is wrong? Anyone have this problem? It takes up to 10 mins. messing with it to get the car out of park.
Old Jun 6, 2006 | 11:25 AM
02 accord's Avatar
Default Re: Gear shift stuck! (jokers1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jokers1 &raquo;</TD></TR><TR><TD CLASS="quote">I put the key in, start the car, press the brake and put the car into gear. Yet the car will not go into gear.</TD></TR></TABLE>
How do you get the trans into gear when you can't even get the shifter out of park?
Check if your brake lights are working. If not, then you have a bad brake light switch. If they are working, you need to check your interlock solenoid to see if it's goin bad. If that works, then you have a problem with the wiring either from the ignition or from the brake light switch.
Modified by 02 accord at 10:44 PM 6/6/2006
Modified by 02 accord at 10:45 PM 6/6/2006
hondabakrgrl
11
Dec 3, 2010 08:17 AM
DRKSol
Acura TL, RL & ZDX
Dec 18, 2009 04:20 PM
rebel98ta
Jul 16, 2008 09:03 AM
coot_er
Aug 23, 2007 02:02 PM
azoodica
Apr 26, 2007 11:02 PM
