f22 power steering pump on h22...
Ok, so I searched, but never got a definitive answer...
will the f22 power steering pump bolt up to the h22 power steering bracket? I think the only differenc e in the 2 pumps is the pulley, which the h22 has more ribs I believe, but I am using my f22 crank pulley, f22 altenator, f22 a/c compressor...so the belts will be the same, and the p/c will be 3 rib. I just need to know if the pump will bolt with no problems?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZacCarter »</TD></TR><TR><TD CLASS="quote">p/s is for girly men.</TD></TR></TABLE>
coming from the man who has power steering
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZacCarter »</TD></TR><TR><TD CLASS="quote">not for long.... bwahaha</TD></TR></TABLE>
much easier to bolt the pump on the bracket and put a blet on, than to take out the whole system..
yes the f22 pump will fit on the h22 bracket. call the place you got the motor from or hmotorsonline and get teh high pressure line for the h22 and take it to a shop and have it put on.
