no spark, no fuel, need help!!!!!!
i've changed the, ecu, fuse box, ignitor, igniton switch, and checked the main relay in all ways, anyone have any ideas?
p.s. started when i pulled a fuse when the car was running because the radio wasn't working.
chech the fuses under the hood, do u have power to the ecu? there should be a red led that comes on as soon as u turn the key on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyemokid »</TD></TR><TR><TD CLASS="quote">i've changed the, ecu, fuse box, ignitor, igniton switch, and checked the main relay in all ways, anyone have any ideas?
p.s. started when i pulled a fuse when the car was running because the radio wasn't working.</TD></TR></TABLE>
which fuse did you pull?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyemokid »</TD></TR><TR><TD CLASS="quote">I WANNA SAY FUSE 10 IS THE ONE THAT I PULLED </TD></TR></TABLE>
and did you bother looking at the diagram to see exactly what fuse 10 does?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyemokid »</TD></TR><TR><TD CLASS="quote">MY DIAGRAM WAS GONE WHENI BOUGHT THE CAR
wow. so you just randomly pulled fuses huh. sounds like your first problem is you never consulted a manual.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyemokid »</TD></TR><TR><TD CLASS="quote">i have a manual, the fuse appered blown from the side view</TD></TR></TABLE>
replace all your fuses first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyemokid »</TD></TR><TR><TD CLASS="quote">i did</TD></TR></TABLE>
so does it crank when you turn the key.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyemokid »</TD></TR><TR><TD CLASS="quote">yeah</TD></TR></TABLE>
check main relay.
check main relay.
yeah i did in all three ways, i searched the archived no spark no fuel stuff but none were the same,but i did all the normal stuff and still don't know what it is
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyemokid »</TD></TR><TR><TD CLASS="quote">yeah i did in all three ways, i searched the archived no spark no fuel stuff but none were the same,but i did all the normal stuff and still don't know what it is</TD></TR></TABLE>
and what was your process for checking the main relay
i connected the battery to two of the prongs and tested continuity with a multimeter on two others i don't remember exactly which ones off hand but i pulled the diagram off honda tech and i tested all circuts this way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyemokid »</TD></TR><TR><TD CLASS="quote">i connected the battery to two of the prongs and tested continuity with a multimeter on two others i don't remember exactly which ones off hand but i pulled the diagram off honda tech and i tested all circuts this way</TD></TR></TABLE>
and you are absolutely sure you are not getting fuel AND spark? so your fuel pump is coming on when you set your key position to ACC?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyemokid »</TD></TR><TR><TD CLASS="quote">the kill switch is a fuel power kill yel/ blk wire </TD></TR></TABLE>
lol so your kill switch is ON right?
have you tried throwing it to off and givin that a try?
