Cam install ?.. head not on block
Hey Ive been working on trying to get my LS/V coupe running. Im almost done getting the correct clearances on the bottom end, and I am currently struggling with the head. I am trying to re-install the gsr cams. Ive been doing research and have found tid-bits of useful info, but Im still not sure. and I know that having the head put together properly is crucial.
This is where Im at:
I have the head off the block and am ready to install cams, caps and all those goodies. I am doing this by the HELMS and it states to install cams with the keyways facing up. The only way the cams sit in is slightly angled keyways pointing towards each other.
Questions:
1) Can I even install cams properly without the head on the block?
2) Do I just proceed with where they sit and tighten down?
3) What DO I DO?!?!?
Please help me get my coupe back on the skreets!
Questions:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by domestic abuser »</TD></TR><TR><TD CLASS="quote">Hey Ive been working on trying to get my LS/V coupe running. Im almost done getting the correct clearances on the bottom end, and I am currently struggling with the head. I am trying to re-install the gsr cams. Ive been doing research and have found tid-bits of useful info, but Im still not sure. and I know that having the head put together properly is crucial.
Questions:
Please help me get my coupe back on the skreets!</TD></TR></TABLE>
1) NO
2) install cams at TDC with the right tightening sequence of the caps and rails.
3) keep reading the helms
Questions:
1) NO
Yea, whoops, I was getting ahead of myself... I cant <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">put the cams on befor trhe ehad is on the block </TD></TR></TABLE>..Too bad they dont have spell check on here..
So when I do strap it up, how will that affect the way my cams will sit inside the journals? Will I sill be experiencing the same thing? This is my first rebuild <--- I know I have lots to learn
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">you put them in and turn them by hand or with a wrench to where they need to be.</TD></TR></TABLE>
once the caps are torqued, the cams will only turn so far. u can bend valves if u move the cam too far, but there would be mass resistance. just remember to install them with bottom and top end at tdc. might not get the cams dead on tdc when torquing the caps, but u do have some movement with them.
16
Dec 22, 2004 03:25 PM
BigC-ivic
12
Oct 26, 2004 07:43 PM
