stock keyless entry antena?
i was wondering were the antena for the stock key less entry/alarm system is at. I talked to people that say if you add more wire to that you can unlock/lock your car from farther away
i have a 2000 civic SI
ya i wasnt expecting like a big radio antenna. but there has to be some sort of wire just hanging down that acts as the antenna. kind of like on garage doors. so does any one know were the controal box for the keyless entry system is? its not any were by the ecu cause i have looked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thefatskeleton »</TD></TR><TR><TD CLASS="quote">i was wondering were the antena for the stock key less entry/alarm system is at. I talked to people that say if you add more wire to that you can unlock/lock your car from farther away
i have a 2000 civic SI</TD></TR></TABLE> The key-less entry module is white and is located in the drivers kick panel, the OEM alarm is to the right of the steering column, [green plug].
There does not have to be an ant., [wire sticking out] it can be built in to the module.
94
94
justfurebay
Audio / Security / Video
Sep 28, 2008 10:43 AM
Unjockable
Mar 8, 2005 12:06 PM
94
