Crower Stage 1's Low Idle - Car Stalls
Old Jun 6, 2006 | 08:15 AM
Spo0NFed E M 1's Avatar
Default Crower Stage 1's Low Idle - Car Stalls
I have a 99 Si with Crower Stage 1's. I bought the car with this setup on Sat. The idle sometimes seems normal, like maybe 600-700rpm's then when I drive, approach a lite and put it in neutral and coast to the lite, the idle drops really low, mostly causing it to stall. I asked the kid what was up he said just to turn the dizzy a LITTLE bit towards the firewall. Should I do that or should I try to do it from the idle air screw?
The car has NO CEL'S. Setup is as follows:
AEM V2. CROWER 1'S, AXLE BACK
Thanks in advance
Old Jun 6, 2006 | 11:16 AM
to the top
Old Jun 6, 2006 | 11:46 AM
Kool Keith's Avatar
crower stage 1's are a very mild cam. They have oem primary lobes with modified Type-R Vtec lobes w/ more duration.
Sounds like you have other issues, are your valves adjusted correctly .007/.008?
Old Jun 6, 2006 | 01:48 PM
C2Imports's Avatar
Default Re: (All MTR xsI)
yeah dont ever just move the distributor around like that, your messing up the ignition timing by doing so, especially advancing it. Valve adjustment sounds right, get one done if u can't do it yourself.
Old Jun 6, 2006 | 03:09 PM
Yambor's Avatar
valve adjustment and clean your iacv or adjust idle speed higher. if it doesnt catch itself when the revs drop, thats a sign of iacv
Old Jun 6, 2006 | 03:30 PM
Default Re: (Yambor)
well i just moved the dizzy a HAIR towards the firewall and adjusted the idle air screw just a bit, seems to be fine now. But did I just cover up a problem that isnt REALLY fixed? Car has 56k miles and he said he adjusted the valves when he did the cams, they dont seem to tick @ all... Thanks, GREAT INFO!
Old Jun 7, 2006 | 09:31 AM
bump
Old Jun 7, 2006 | 10:04 AM
GUILOTINE's Avatar
Kill Gil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All MTR xsI &raquo;</TD></TR><TR><TD CLASS="quote">well i just moved the dizzy a HAIR towards the firewall and adjusted the idle air screw just a bit, seems to be fine now.</TD></TR></TABLE>
you need a timming light do adjust it correctly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All MTR xsI &raquo;</TD></TR><TR><TD CLASS="quote">Car has 56k miles and he said he adjusted the valves when he did the cams, they dont seem to tick @ all... </TD></TR></TABLE>
they dont tick becuae they are probably too tight
Old Jun 8, 2006 | 10:18 AM
too tight? could that be the cause of the car's idle being ALL OVER THE PLACE! like it changes @ every other lite, from 900rpms to 550rpms? And sometimes when I come to a stop and push in the clutch the idle wont catch itself, like it almost stalls.
Old Jun 9, 2006 | 11:17 AM
bump
Old Jun 10, 2006 | 07:23 AM
a.m. bump
Old Jun 10, 2006 | 10:13 AM
Okay so today it finally threw a CEL, So I brought it to Advanced Auto and they printed me out the data. It says:
P0172
System Too Rich
(Bank 1)
P0170
Fuel Trim
Malfunction
(Bank 1)
Does anyone have any experience with OBD2 CEL'S? And can tell me what the hell this means and how I fix it. I am pissed cuz I just bought this car 1 week ago and this **** is already starting!! I called the seller and asked him about the valve adjustment he did and he said "Well we can do it over on Monday if you want?" So i said yes. Maybe too tight? Too Looose, I dunno..anyone?
Thanks in Adv.
Old Jun 10, 2006 | 11:31 AM
bump. What about the timing being off? Can I check that out with a timing lite? Will the lite be able to tell me whether or not the cams are off? Because I have been doing alot of searching and been leading towards either a problem with the primary o2 sensor or the timing/cams/valves being off adjustment because the person i bought it off said he out the cams in recently and adjusted the valves during the process.
Old Jun 10, 2006 | 06:14 PM
cltitus's Avatar
crower stage 1 are almost lieks tock should just been easy drop in looks like you need to tune it.
Old Jun 11, 2006 | 05:14 AM
bump. He said they were off his friends GSR, GSR cams are no different tho rite? And what about valves too tite?
Old Jun 12, 2006 | 04:31 AM
bump. anyone have valve adj specs for my car. hes comin over this morning to redo them and loosen the belt cause i hear some whining noises like the belts too tite or somethin?
Old Jun 14, 2006 | 01:07 PM
bump
iMPoRT GeeK
Jul 29, 2007 12:32 AM
RP215.
Apr 23, 2006 12:52 AM
ActiveAero
Aug 29, 2003 10:12 PM
DsITR
Sep 23, 2002 07:36 AM
baonest
May 16, 2002 09:37 PM
