unusually low idle vacuum readings with pro1 cams
Old Jun 6, 2006 | 07:38 AM
an2ny888's Avatar
Default unusually low idle vacuum readings with pro1 cams
i'm only pulling 13 - 14 in/hg of vacuum with the pro1's on my b18c, is this normal? does it have something to do with my iac valve? i bypassed the water hoses leading into the iac valve, but this never caused a problem when i had bc3+ cams before
Old Jun 6, 2006 | 09:15 AM
pomansouth01's Avatar
Ginger Kid
Default Re: unusually low idle vacuum readings with pro1 cams (an2ny888)
do a search, but I will tell you them main factor here is overlap... so much overlap from these cams leads to low vacuum at idle... Advance your exhaust cam to about 5 degrees advance...
quick99gs-r
May 25, 2009 06:35 AM
Teamdiesel
Jan 16, 2006 07:35 PM
Crisgo
Apr 7, 2004 08:06 AM
TEGPOWER44
Jan 26, 2003 11:48 AM
