NEED HELP, b16a swap with YS1 transmission
Old Jun 6, 2006 | 05:42 AM
sweetdang's Avatar
Default NEED HELP, b16a swap with YS1 transmission
I originally had a b16a motor with the s1 transmission cable. The s1 broke and then I bought a YS1 transmission from a ls integra. The problem is the YS1 tranny won't slip into place, are the clutch and flywheels different. If so what clutch do I buy and can I use the flywheel from the S1 transmission.
Old Jun 6, 2006 | 06:29 AM
si90rex's Avatar
Default Re: NEED HELP, b16a swap with YS1 transmission (sweetdang)
it should fit fine. you should have to get a new flywheel or clutch. my buddy's hatch had a ls b18a1 in it and we have put a two YS1's and a Y1 and never change a thing. it should bolt right out are sure you got the spines in the tranny lined up with the clutch right.
Old Jun 6, 2006 | 08:26 AM
haggar's Avatar
Default Re: NEED HELP, b16a swap with YS1 transmission (si90rex)
Early S1 transmissions (90-91) have a different number of splines. Count them on both, if you still have the old trans.
You can reuse your current flywheel and pressure plate, but will need a new clutch disc if you indeed have this issue.
Old Jun 6, 2006 | 12:21 PM
firme ef8's Avatar
Default Re: NEED HELP, b16a swap with YS1 transmission (haggar)
you have to buy a new clutch because of the spline count.
Old Jun 6, 2006 | 12:36 PM
ludesrv's Avatar
Default Re: NEED HELP, b16a swap with YS1 transmission (xownsx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xownsx &raquo;</TD></TR><TR><TD CLASS="quote">you have to buy a new clutch because of the spline count.</TD></TR></TABLE>
Only if the count is different. Some aren't.
Old Jun 6, 2006 | 01:47 PM
REDBARON's Avatar
Default Re: NEED HELP, b16a swap with YS1 transmission (ludesrv)
I have a YS1 (LS) transmission in my B16 and I had to get a new clutch. Just get one from a 90-93 Integra. I also had an S1 previously.
Old Jun 6, 2006 | 01:49 PM
court's Avatar
25 Year Member
Default Re: NEED HELP, b16a swap with YS1 transmission (REDBARON)
only a 92-00 b series disc will work
Old Jun 6, 2006 | 03:17 PM
Crx Jimmy's Avatar
Default Re: NEED HELP, b16a swap with YS1 transmission (court)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by court &raquo;</TD></TR><TR><TD CLASS="quote">only a 92-00 b series disc will work</TD></TR></TABLE>
correct
Old Jun 6, 2006 | 06:36 PM
sweetdang's Avatar
so the 92-93 integra ls clutch will work? Or do I have to buy the 99-00 si clutch, but I thought 92-00 were all hydraulic
Old Jun 6, 2006 | 08:18 PM
sweetdang's Avatar
also could I buy a clutch disc for 92-93 ls and will it still built up to the b16a clutch housing
Old Jun 6, 2006 | 08:37 PM
court's Avatar
25 Year Member
Default Re: (sweetdang)
let me help you out bud
all 92+ b series transmissions, ALL, have the same size output spline shaft.
ys1, y21, y80, s80,
Old Jun 6, 2006 | 08:49 PM
sweetdang's Avatar
Default Re: (court)
this might clear up what I'm trying to say better, I have a first generation b16a, which is older than a 92, just seeing if I could use my existing clutch housing and only have to purchase the clutch disc from a 92-92 integra to save some money. The point is I'm bolting a pre-91 b16a to a 92 ys1 tranny and need to know if I could use my existing exedy clutch housing that was first used with a s1 transmission to a exedy clutch disc from a 92-93 integra. I just didn't know if the bolt pattern for the clutch were the same.
Old Jun 6, 2006 | 08:57 PM
court's Avatar
25 Year Member
As stated before, you need a 92+ B series disc.
the term you are looking for is Pressure Plate, not housing.
GroundZer0 336
Jan 13, 2010 07:40 PM
c0d0r
Jun 10, 2007 03:35 PM
daidilus
Jan 6, 2006 04:59 AM
RHDwhor3
Jul 4, 2005 10:05 PM
bambam
May 3, 2004 08:22 AM
