Block Guard to repair minor Head gasket leak??
So I have a small minor leak on my head gasket and I dont feel like dishing out 750bucks on repair and dont feel like doing all tat work myself. So I bought this thing called Block Guard which is supposed to fix leaks in blocks/radiator and also head gaskets. Has anyone ever used this and does it really work good? I wanna give this a shot to save money and since head gasket has just monor leak. Thanks.
some shoparound my area. I wanna try this stuff before I do headgasket swap. I never removed a head and afraid of meing something up. I mean its worth a try using block guard dont you think?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junior40er »</TD></TR><TR><TD CLASS="quote">some shoparound my area. I wanna try this stuff before I do headgasket swap. I never removed a head and afraid of meing something up. I mean its worth a try using block guard dont you think?</TD></TR></TABLE>
no, its not.
no, its not.
I might try it and if it doesnt work then I'll attempt to change my own head gasket. This is temporary since I wanna drop an H in there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junior40er »</TD></TR><TR><TD CLASS="quote">I might try it and if it doesnt work then I'll attempt to change my own head gasket. This is temporary since I wanna drop an H in there.</TD></TR></TABLE>
just change the headgasket. dont be lazy.
if it the stuff you add to your rad, it can really mess **** up. the stuff that fixes leakes also clogs your rad and heater core
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 »</TD></TR><TR><TD CLASS="quote"> Just take the head off, change the headgasket, and call it a day. Who charges 750 for that?</TD></TR></TABLE>
Before all that though, don't you need to.. drain oil, drain coolant, take off intake manifold, take off exhaust manifold/header, remove valve cover, and then remove the head?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rayzian »</TD></TR><TR><TD CLASS="quote">
Don't you need to... drain oil, drain coolant, remove coolant hoses, take off intake manifold, take off exhaust manifold/header, remove valve cover, remove the head, and scrape off old baked headgasket first?
I figured this covered it and all that's involved, but I could have been a little more detailed, huh?
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 »</TD></TR><TR><TD CLASS="quote"> Just take the head off, change the headgasket, and call it a day. Who charges 750 for that?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 »</TD></TR><TR><TD CLASS="quote">I figured this covered it and all that's involved, but I could have been a little more detailed, huh?
Well you're making it sound so easy for us first timers
</TD></TR></TABLE>Well you're making it sound so easy for us first timers
it is, remove bolts, slide belt, put gasket, reinstall bolts and belt
</TD></TR></TABLE>it is, remove bolts, slide belt, put gasket, reinstall bolts and belt
I will get a manual and attemp it. You guys gave me confidence and convinced me. I am just worried of re-assembly. Do I also HAVE to change my head studs or can I use the same ones. I dont race engine since its stock motor. Only thing I have is a AEM short ram intake since it was there when I bought it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junior40er »</TD></TR><TR><TD CLASS="quote">I will get a manual and attemp it. You guys gave me confidence and convinced me. I am just worried of re-assembly. Do I also HAVE to change my head studs or can I use the same ones. I dont race engine since its stock motor. Only thing I have is a AEM short ram intake since it was there when I bought it.</TD></TR></TABLE>
just get new ones.
just get new ones.
I did a search and didnt see anything. Is there a write anywhere with detailed pics on changing head gasket??
It's not a must, but it's a crutial part of the engine, and you might aswell replace them. Aswell, don't get alot of oil inside the thread holes for those bolts. Oil doesn't compress very well and will crack the block if the pressure gets too high. Using a screw driver and dipping it in until no oil comes out is usually what I do, nothing had ever gone wrong.
Get a manual that explains it. It's an easy job, it's just not something you wanna screw up haha.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junior40er »</TD></TR><TR><TD CLASS="quote">I did a search and didnt see anything. Is there a write anywhere with detailed pics on changing head gasket??</TD></TR></TABLE>
shop manual.
shop manual.
I got one of those block guards. but that was becuase the guy o bought the car from used a big screwdriver or prybar to get the head off and tooka big chunk out of the cylinder lip/ I hammered in a block guard and put some JB Weld on the chip, slapped on a new head gasket and the car passed emissions today.
I beat the crap out of it to make sure it held. just make sure that when you put the head bolts on, go to 1-2 lbs. below what is required, let the motor warm up, and then retorqe the bolts to the correct specs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">
shop manual.</TD></TR></TABLE>
go to honda-hookup.com, download the 88-91 crx/civic manual. under the engine tab there will be a cylinder head removal/instalation tab. all you need to know is there. pics, torque specs and all. and you may be able to leave on the intake mani so you dont have to change the im gasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jacoop86 »</TD></TR><TR><TD CLASS="quote">
go to honda-hookup.com, download the 88-91 crx/civic manual. under the engine tab there will be a cylinder head removal/instalation tab. all you need to know is there. pics, torque specs and all. and you may be able to leave on the intake mani so you dont have to change the im gasket.</TD></TR></TABLE>
or hybrid.honda-perf.org
If your not doing the timing belt and water pump it is a much faster job. The only downside is removing the old crappy gasket. Cleaning the top of the block took me forever.
Plus I think you can use a z6 or y8 metal gasket and get a little more compression but dont quote me on that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxcess »</TD></TR><TR><TD CLASS="quote">I hammered in a block guard and put some JB Weld on the chip, slapped on a new head gasket and the car passed emissions today.
some pretty good info. I know shop manual helps but I personally preffere a Online write up cause I can see peoples feedbacks, response and outcomes.
