Vtec selanoid torque specs?
Old Jun 6, 2006 | 04:58 AM
Master23's Avatar
Default Vtec selanoid torque specs?
Anybody know the torque specs to the Vtec selanoid housing that connects to the cylinder head and the selanoid ontop of the spool valve housing?
Old Jun 6, 2006 | 05:10 AM
SOHC4life 96's Avatar
Default Re: Vtec selanoid torque specs? (Master23)
Just do it hand tight. If you have the torque wrench that goes low enough it's most likly in the inch/pound range. But hand tight will do just fine.
Old Jun 6, 2006 | 05:24 AM
Master23's Avatar
Default Re: Vtec selanoid torque specs? (SOHC4life 96)
I doubt that hand tightening the bolts down will suffice and probably wont give the O-rings a proper seal. I read somewhere that it was 8 pounds but I need to confirm with others if thats correct or not becuase I've tightened down he bolds on the solenoid but its steal leaking oil.
Old Jun 6, 2006 | 06:18 AM
I meant hand tight with a wrench. If you replaced the gaskets/o-rings and it's still leaking, you have different problem.
MisterB
Jun 21, 2019 09:39 PM
Cameron k.
Sep 24, 2012 06:17 PM
scspeed
Feb 12, 2009 08:31 AM
hybrid1990crx
Aug 2, 2005 02:01 AM
