Removing back seats
I was just wondering if anyone can tell me how to remove the rear seats out of a integra hatchback. I searched but only found how to take them out in an accord.
Just take a good look at it and you will see what holds it down. Take off the top part first, the part your back rests on. You should be able to just pull the bottom part out after that.
A clip on each side holds the seatbacks in. Remove the clip and push the seatback towards the outside to get it off of the pin in the middle. After both backs are out, one bolt holds the lower cushion in. After removing the bolt, flip the lower cushion foward and pull it away from the body of the car (this can be difficult, the clips that hold it in are shaped wierd).
Just come clarification
A clip on each side holds the seatbacks in. It's a black clip that goes around the pin that's in the bottom of the outside part of the seat. Remove the clip and push the seatback towards the outside to get it off of the pin in the middle. In the middle of the two seats, that is. After both backs are out, one bolt holds the lower cushion in. It's located at the top center of the lower cushions. After removing the bolt, flip the lower cushion foward and pull it away from the body of the car (this can be difficult, the clips that hold it in are shaped wierd). Yes they are.
S-=N=-A-=K=-E
Jun 13, 2006 12:57 AM
