H22a oil consumption question
Old Jun 5, 2006 | 10:05 PM
DAGAME's Avatar
Default H22a oil consumption question
ok here is the story... i have 96 cd7 accord with 1998 JDM H22a that was honed and reringed awhile ago, the engine had bigger injectors on stock p13 obd2 so it was running rich and is contantly burning oil especially in Vtec, i would go through about 1 qt per week, well i changed back to stock 290 cc injectors and took out accord resistor box and still burns oil just as bad, doesnt smoke as much anymore but still burns oil the same. What can solve my problem? Do i have to machine the block with oversized pistons/rings?
And another oil question, the engine always ran castrol synthetic blend and 4 or 5 months ago i switched to mobile 1 full synthetic and burning as much as it does i have to spend $60 a month on oil, at my work we use synthetic blend that i can use for free, is it safe to switch back to the castrol blend with out damaging my motor? Its my daily driver so i cant afford to be out of a car if i throw a rod.
Old Jun 6, 2006 | 12:08 AM
HondaccordH22aJdm's Avatar
Default Re: H22a oil consumption question (DAGAME)
the JDM ecu is configuered to run rich. if u dont want it to run rich u need to get a new ecu.
Old Jun 6, 2006 | 03:42 AM
DAGAME's Avatar
fuel system doesnt run rich anymore no cel code is on for running rich
Old Jun 6, 2006 | 07:30 AM
v4lu3s's Avatar
RTFM
you probably have worn out rings from using gasoline to lubricate them while running very rich.
Old Jun 6, 2006 | 07:33 AM
-Bionic-'s Avatar
Former Sponsor
It;s normal to burn oil in vtec.
Are you bruning oil at idle?
Old Jun 6, 2006 | 11:05 AM
Chuckles99SH's Avatar
Make sure who ever did your hone did it right, Honda has a VERY tight spec that lots of shops cant match... if your hone was done wrong or out of spec that would cause your motor to eat oil like that.. a normal h22 should burn oil in vtec but not a quart a week... You can overbore and hone again but if you dont follow the hone procedure then you will be in the same place again..
Old Jun 6, 2006 | 06:03 PM
DAGAME's Avatar
how much do you think a performance shop would normally charge for putting in oversize type s pistons with rings and honing the block?
Old Jun 6, 2006 | 10:22 PM
momstaxi's Avatar
Default Re: (DAGAME)
yes, h22's due to their special sleeve material require a special honing process, possibly your machine shop was not aware of this and honed like a standard iron sleeved block...could be the cause of your excessive oil consumption
tr0n9h
Sep 25, 2005 05:49 PM
Gen5lude
Sep 13, 2005 08:57 AM
biggs2.3
Jul 24, 2004 09:06 AM
Slipknt777
Jul 12, 2004 03:16 AM
AccordVtec
Jun 21, 2004 07:35 AM
