h22 swap into 4th gen, and now ac/altenator belt won't fit...
Old Jun 5, 2006 | 09:53 PM
.BigSexy's Avatar
most hood white kid
Default h22 swap into 4th gen, and now ac/altenator belt won't fit...
So I just did my h22 swap, and I was getting around to putting in my a/c compressor, altenator, and then we go to put it in, now here is what I did, I used my f22 crank pulley, f22 a/c compressor, f22 altenator, and the f22 ac/altenator belt, and now the belt will not fit!! what gives?
also, what power steering bracket do I have to use to retain p/s? I tried using the one from my f22 and it does not fit, someone help me out!
Old Jun 5, 2006 | 11:22 PM
.BigSexy's Avatar
most hood white kid
Default Re: h22 swap into 4th gen, and now ac/altenator belt won't fit... (egcoupe94)
bump
Old Jun 5, 2006 | 11:28 PM
NeriVTEC's Avatar
For the PS bracket you need the H22 one, now for the belt how exactly doesn't it fit?
Old Jun 6, 2006 | 01:39 AM
skinnyboy's Avatar
Default Re: h22 swap into 4th gen, and now ac/altenator belt won't fit... (NeriVTEC)
I had the same problem. Basically use the F22 accesorries and belts. The belt should be a 4 rib for the F22 and the H22 should have a 5 rib pulley. Just use the same belts.
As for the bracket, you need a H22 one.
see the answers i got about it here https://honda-tech.com/zerothread?id=1639489
Old Jun 6, 2006 | 01:56 AM
I Got The CD5 Jeebies!!!'s Avatar
you used prelude motor mounts huh???? who needs power steering?? on my H22 swap in a 5th gen I just took all the stuff out...to have PS you have to make a line using longer tubing......but it can be done
Old Jun 6, 2006 | 08:22 AM
.BigSexy's Avatar
most hood white kid
Default Re: h22 swap into 4th gen, and now ac/altenator belt won't fit... (skinnyboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skinnyboy &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem. Basically use the F22 accesorries and belts. The belt should be a 4 rib for the F22 and the H22 should have a 5 rib pulley. Just use the same belts.
see the answers i got about it here https://honda-tech.com/zerothread?id=1639489 </TD></TR></TABLE>
see...I am using the f22 belt and accessories. that is what is throwing me off. The belt willl come to the lip to the altenator pulley and thats it...
Old Jun 6, 2006 | 10:27 AM
.BigSexy's Avatar
most hood white kid
another question, can my f22 power steering pump work with a 4th gen. h22 power steering bracket??
also, will the plug from my f22 dizzy wqork on the h22 dizzy? I am trying to have this running before Saturday morning...
Old Jun 6, 2006 | 11:24 AM
prelude1897's Avatar
If you need a bracket for your H series motor, I have an extra one from my swap I can sell you...Just let me know
Old Jun 6, 2006 | 11:53 AM
.BigSexy's Avatar
most hood white kid
Default Re: h22 swap into 4th gen, and now ac/altenator belt won't fit... (prelude1897)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">If you need a bracket for your H series motor, I have an extra one from my swap I can sell you...Just let me know </TD></TR></TABLE>
pm'd
Old Jun 6, 2006 | 12:06 PM
replied
nemesis25
Aug 31, 2011 01:56 PM
v1sion
Apr 5, 2011 01:43 PM
bdpetska
Jul 15, 2007 11:39 AM
.BigSexy
Jun 7, 2006 05:24 PM
.BigSexy
Jun 5, 2006 11:20 PM
