gears wont go in the accord??help?
i know its not the tranny or the clutch cuz ,clutch still has life and when car is off, gears go in and i try to start it while in gear and it moves,but turns off like it should.the gears wont go in,(feels like clutch isnt grabbing)i noticed the slave cylinder pushing,and bled the lines.COULD IT BE THE clutch RELEASE BEARING??
I would inspect your master and slave cylinder first. If your starting it in gear and it lurches forward the cluth isn't disengaging when you have the pedal pressed in it is possible that it's release bearing but I would look into the master and slave cylinders first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 »</TD></TR><TR><TD CLASS="quote">Does the clutch have any resistance or does it move freely?</TD></TR></TABLE>
lo0nY
Feb 26, 2006 03:58 PM
VOLTRONRacing
Nov 4, 2005 06:20 AM
johnqt3
Oct 7, 2005 11:05 AM
