skunk2 intakemanifold, IACV bracket, which one?
IVE SEARCHED
i need to know what brackets go where on the intake manifold, i bought it second hand new but the instructions didnt come from it.
pics, or if someone could scan the info and send it to me
i'll tell you what put the 152 brackets and manifold back in the box give it back to whomever you bought it from demand your money back and kick him as hard as you can in the nuts then bitch slap yourself for actually buying it.
okay the two brackets you can actually get rid of because you don't need it for the egr valve. unless you just want it dangling in the eng bay for no reason. just concentrate on the iacv. once installed start your car and see if it actually idles. it will be jumpy but if it stalls then you did something wrong.
seriously dude this is not brain surgery, you hold the iacv in one hand, and u find a brakcet that matches and can bolt to it, then u bolt that on. and then u get the matching bracket for the back of the intake manifold and u bolt that one on.
if you really cant figure that out, i suggest you don't bother trying to install it yourself.
there are 2 that line up on the back of the intake mani that look like lines for the IACV would goto.
i guess you use those if you arnt going to use an IACV.
then there is another bracket with like 4 quarter size holes in it.
