taking off break hub?
Old Jun 5, 2006 | 06:53 PM
stemiched's Avatar
Default taking off break hub?
alright well im going to just start out by saying i dont know mechanical lingo... so just bear with me... and i did look, if i missed a thread about this just someone direct me to it with a link.
okay so i have a 91 crx si (suposubly) that is my driving car, and an 88 crx si (subosubly) that is my parts car, so 2 of the lugs on the back right tire are stripped to hell and the 88 are in great condition i want to know how i can swap them. i know the si is sapose to be disk breakes but im fearly sure neither of them are disck brakes... the front brakes are deffinately not the same as the back... so im going to assume there not disk brakes, maybe someone can show me a pic of disk brakes so i will know. alright so i need a diagram on how to take off and swap the lugs... not the nuts... the thing the nuts screw on to... sorry that i dont know the lingo
Old Jun 5, 2006 | 06:58 PM
b16_madman's Avatar
Default Re: taking off break hub? (stemiched)
you're wanting to replace your rear wheel studs.
go up to the FAQ & go to Honda's uk website & there you can find a .pdf file of everything you're needing help on.
It's pretty easy for the rears, fronts require a lot more work.
you'll need:
32mm socket
breaker bar
flathead
bigass hammer
etc
remove drum to expose shoes, don't huff the dust
before you take anything apart remove the dust cap w/a flathead n a hammer or something
then unbolt the 32mm bigass nut
n it's easy as pie
i'm swapping out 2 ef's suspension these next fwe evenings.
Old Jun 5, 2006 | 07:06 PM
stemiched's Avatar
Default Re: taking off break hub? (b16_madman)
um that did help and that is what i want to be doing, but could you give me a direct link to that maybe... i got lost...
Old Jun 5, 2006 | 09:24 PM
b16_madman's Avatar
https://honda-tech.com/zerothread/1508680
in faq 2.0:
http://www.honda.co.uk/car/owner/workshop.html
http://spoonhonda.com/downloads.htm
can't get lost now
glazedham42
Mar 19, 2010 03:38 PM
newman271
Oct 29, 2006 01:12 AM
Xemu
Sep 19, 2006 10:23 AM
Death_to_Thieves
Nov 5, 2004 07:59 AM
xXx Justin xXx
Jun 7, 2002 02:53 PM
