HELP!! What size tap for GSR ARP Head studs????
Old Jun 5, 2006 | 12:04 PM
QuarterMileMaster's Avatar
Default HELP!! What size tap for GSR ARP Head studs????
I did a search and couldn't find it. I just need to know what size tap I need to use to clean the threads in my GSR block before I put the ARP's in. I've heard 11x1.5 and I've heard 12x1.5. If it's 11x1.5 I'm screwed because I can't find that anywhere. Please help. Thanks!
Old Jun 5, 2006 | 12:31 PM
Circuit Star-29's Avatar
Default Re: HELP!! What size tap for GSR ARP Head studs???? (QuarterMileMaster)
Just measure the thread pitch of the Stud?
Or....call ARP Technical Support: 800.826.3045 or 805.339.2200
Old Jun 5, 2006 | 12:55 PM
Default Re: HELP!! What size tap for GSR ARP Head studs???? (Circuit Star-29)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 &raquo;</TD></TR><TR><TD CLASS="quote">Just measure the thread pitch of the Stud?
Or....call ARP Technical Support: 800.826.3045 or 805.339.2200</TD></TR></TABLE>
Yeah I called ARP and a chick said it was 11mm by 1.5. But I find it hard to believe that it's an 11mm. And I can find an 11mm tap anywhere.
Old Jun 5, 2006 | 01:21 PM
IN VTEC's Avatar
It's M11x1.5. You can get a tap from Sears in the metric tap set.
Use an assortment of a 1/4" extension, 1/4" drive 10mm socket, M6x1.00 bolt, and M6x1.00 nut to create an extension to thread the tap down into the block if you don't have tap wrench that is long enough.
Old Jun 5, 2006 | 02:19 PM
Default Re: HELP!! What size tap for GSR ARP Head studs???? (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">It's M11x1.5. You can get a tap from Sears in the metric tap set.
Use an assortment of a 1/4" extension, 1/4" drive 10mm socket, M6x1.00 bolt, and M6x1.00 nut to create an extension to thread the tap down into the block if you don't have tap wrench that is long enough.</TD></TR></TABLE>
Crap, that's what I was afraid of. I found a kit from a local tool outlet that has it finally. Thanks alot for the info!
gooblinn258
May 4, 2014 01:48 PM
hondacamp909
Jan 25, 2009 06:42 PM
avotegra
Apr 20, 2008 11:50 AM
redbarchetta
Dec 11, 2006 12:22 PM
justagsr
Mar 18, 2003 07:25 PM
