h22 pro2 cams won't idle!! any suggestions
Old Jun 5, 2006 | 10:56 AM
j spec's Avatar
Default h22 pro2 cams won't idle!! any suggestions
just installed some skunk2 pro series stage 2 cams in a friends h22 and it won't idle. the bottom end is stock, head has been ported and has portflow valvetrain with ferrea valves. car drives fine after about 1500 rpm also vtec doesn't feel very strong (may not have anything to do with idle which is what im focused fixing). the car has proseries camgears set at 0 degrees.
Old Jun 5, 2006 | 11:55 AM
VtecFreePrelude's Avatar
get it timed and see what happens.
any other work done? milled head ect.
and when you say doesn't idle do you mean it stalls below 1500 or something else
Old Jun 5, 2006 | 11:58 AM
98vtec's Avatar
moderator emeritus
Default Re: (VtecFreePrelude)
pretty wild cam for a stock bottom end. What did you expect? a non tuned motor with wild cam and minimal compression to run perfect?
Old Jun 5, 2006 | 12:10 PM
j spec's Avatar
Default Re: (98vtec)
what did expect? as i stated previously i installed these for a friend not on my own car i didn't expect anything. the car should idle fine with these cams they are not that much different than the regular skunk2 stage 2's and i know of plenty of people running these as daily drivers with stock bottom ends with no idls problems at all.
Old Jun 5, 2006 | 02:31 PM
Dai_Ca_Vietnam_H22a4's Avatar
Default Re: h22 pro2 cams won't idle!! any suggestions (roma's GSReg6)
I getting the pro series stage 2 install this Saturday. I will tell you how it idles. But then again, I have 11.5:1 compression.
Old Jun 5, 2006 | 02:53 PM
A Blue Lude's Avatar
Default Re: (roma's GSReg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roma’s GSReg6 &raquo;</TD></TR><TR><TD CLASS="quote">the car should idle fine with these cams they are not that much different than the regular skunk2 stage 2's and i know of plenty of people running these as daily drivers with stock bottom ends with no idls problems at all.</TD></TR></TABLE>
Are they really? For the B-series the Pro1 is roughly similar to the Stage 2 cam in terms of wildness. I can only imagine that the H-series Pro lineup is just as big.
Old Jun 5, 2006 | 05:41 PM
98vtec's Avatar
moderator emeritus
Default Re: (A Blue Lude)
being the reason why i said what i said.
Old Jun 5, 2006 | 10:01 PM
Buffalo's Avatar
hurry up and find a solution bish cos i have big plans for those cams
Old Jun 6, 2006 | 12:27 AM
94vtirozguy's Avatar
get an aftermarket ECU and tune it.. some cam gears might help too...
Old Jun 6, 2006 | 08:09 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">pretty wild cam for a stock bottom end. What did you expect? a non tuned motor with wild cam and minimal compression to run perfect?</TD></TR></TABLE>
they run fine on a stock compression.
Hell, I run Crower 3's on stock USDM H22 compression
Old Jun 6, 2006 | 08:15 AM
98vtec's Avatar
moderator emeritus
Default Re: (skunked)
then again, you are tuned, you have close ratio gears. Those kinda compensate for the large cam.
what are the exact specs of the pro 2's?
Old Jun 6, 2006 | 08:20 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">then again, you are tuned, you have close ratio gears. Those kinda compensate for the large cam.
what are the exact specs of the pro 2's?</TD></TR></TABLE>
tuned? Of course
2.2EG on this board has the cams in his jdm h22 with a Skunk manifold. Makes 220/156 on a dynojet, H2B car as well.
Old Jun 6, 2006 | 08:30 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">tuned? Of course
exactly the answer to his problem.
Old Jun 6, 2006 | 08:41 AM
skunked's Avatar
My car drove and idled fine without a tune. I did gain another 7-8 whp peak from the tune thoough....
I would just make sure everything is lined up at TDC
Old Jun 6, 2006 | 08:51 AM
Honda318dx's Avatar
Could be a stupid question, did you adjust the valve lash after the install, if not you could have 16 bent valves.. I know its obvious, but just thought I would ask
Old Jun 6, 2006 | 06:23 PM
j spec's Avatar
Default Re: (Honda318dx)
i did adjust the valves to factory spec .007 intake .008 exhaust.
eg_h22
Aug 16, 2007 02:17 PM
j spec
Dec 20, 2006 07:36 PM
j spec
Jun 6, 2006 06:36 PM
VTEC Visions
49
Sep 3, 2005 11:19 PM
cs_x21
Jun 25, 2003 03:54 PM
