Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Replacing a b20b with a b20z?
Old Jun 5, 2006 | 09:51 AM
miksew's Avatar
Default Replacing a b20b with a b20z?
Is it straight bolt in? What parts would I need from the b20z donor car to make it work? ecu? axles? mounts?
Its a 97 CRV with a b20b currently in it. Gotta love the edit haha.
Modified by miksew at 6:46 AM 6/6/2006
Old Jun 5, 2006 | 12:21 PM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: Replacing a b20b with a b20z? (miksew)
straight bolt in to what?
Why would you make a thread and not even be able to give details?
Old Jun 5, 2006 | 12:37 PM
crvpimpin's Avatar
Default Re: Replacing a b20b with a b20z? (MooGoCow3)
dont be to harsh he did say hes replacing the b20b with a b20z
and i dont know if it is a direct swap sorry
Old Jun 5, 2006 | 01:16 PM
Ross 2.0's Avatar
Default Re: Replacing a b20b with a b20z? (crvpimpin)
I was just giving it back to him from a previous thread. it's all good.
Old Jun 5, 2006 | 09:45 PM
crvpimpin's Avatar
ok i see
Old Jun 5, 2006 | 09:46 PM
miksew's Avatar
I clearly stated that its a 97 crv already.
Old Jun 6, 2006 | 12:25 PM
Ross 2.0's Avatar
Ok just had to get it straight.
Really i'm not sure. You may want to ask in the teg area. The swap may have been done before into one of those. So the reverse steps could be used.
Old Jun 6, 2006 | 12:50 PM
crvpimpin's Avatar
Default Re: (MooGoCow3)
i think it should work
but realy why bother
what would the differance be a couple of hp
it would most likly be cheaper to
like for example i am going to do a b16 head swap
higher comp pistons and stronger rods i hope it'll put out about 180 or so to the wheels
Old Jun 7, 2006 | 10:32 AM
fracas's Avatar
Its a Direct swap. You will need to used your Complete Mani and Dizzy on the B20z2.
Old Jun 10, 2006 | 02:57 PM
spoonfedcrx's Avatar
I did motor at work for a customer it was a 99 crv i believe. Motor grenaded and parts ordered a jdm b20. One was a z one was b. They had diffrences in the oil pumps had to be swapped because of crank sensor locations. Don't know if this applies to US motors or be any help. This was a long time ago so details a little foggy.
Old Jun 11, 2006 | 03:02 PM
T-RO's Avatar
yeah, i dont think it would be worth it either if youre trying to upgrade. if youre replacing a damaged motor then its a different story.
97 Civic LX
Dec 27, 2018 03:54 PM
Jacob Downes
Apr 23, 2018 06:03 PM
Carboy93
Mar 26, 2012 05:48 AM
AllMadd
Jul 24, 2010 12:23 PM
Oacosta27
Dec 7, 2006 12:48 PM
