si transmission into dx
Old Jun 5, 2006 | 07:37 AM
dwerpk's Avatar
Default si transmission into dx
Hi i have a 1989 crx dx i was wondering if i could take a 90 si transmission and put it into my car i have the clutch shift linkdges and the axels
Old Jun 5, 2006 | 07:40 AM
Autoworks's Avatar
Default Re: si transmission into dx (dwerpk)
yes
Old Jun 5, 2006 | 07:42 AM
ludesrv's Avatar
Keep your 89 flywheel and clutch. Do not try to match 88-89 clutch or flywheel with 90-91 clutch or flywheel. They will not work togeter.
Old Jun 5, 2006 | 08:06 AM
dwerpk's Avatar
thanks yea i knew that the 88-89 one was smaller thats y i have the full flywheel clutch pp asembly from an si
Old Jun 5, 2006 | 04:34 PM
extensioncordy's Avatar
what do i need to put a SI tranny into my 1991 std hatch
Old Jun 5, 2006 | 05:09 PM
ryan89crx's Avatar
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">Do not try to match 88-89 clutch or flywheel with 90-91 clutch or flywheel. They will not work togeter.</TD></TR></TABLE>sure they will. an 89 clutch will work just fine on a 90 flywheel. the surface is bigger on the flywheel than it is on the clutch, so technically, there would be nothing to interfere with it.
either way, a good general rule is to keep the years the same unless its 90+
GameBoyeas
Aug 10, 2016 05:50 AM
matt's hatch
Jan 30, 2010 06:03 PM
CRXalwysk8
13
May 3, 2005 07:18 AM
Donkey85
Jul 27, 2004 03:24 PM
the DR.
Feb 10, 2002 08:13 PM
