Sony XM-2150GSX, 2 ID12V.2 D4 Image Dynamics Subs, in a Sealed Box
Old Apr 15, 2002 | 09:01 AM
bhaz413's Avatar
Default Sony XM-2150GSX, 2 ID12V.2 D4 Image Dynamics Subs, in a Sealed Box
I am selling a Sony XM-2150GSX Amp with a 3 year warrenty from Best Buy and 2 12inch ID12V.2 D4 Image Dynamics Subs, in a Sealed Box. Below are the specs on each product. Subs are less then a year old, and the box and amp are 2 months old. The reason I am getting rid of my audio equipment is because I want more parts for my car, and I dont need the extra weight. There are nothing wrong with the subs/amp. Perfect condition.
I may also trade this equipment for parts for my car. Just let me know what you have to offer and we may have a trade. E-mail me with a price for both, or what you have to trade at erik_maloney@hotmail.com
Thanks guys!
http://www.sony.com http://www.imagedynamicsusa.com/webs...oducts/id.html
Here are the Specs,
AMP
The Details on the Amp
760 Watts Max Power (into 2 ohms)
150 Watts x 2 into 4 Ohms, 20-20 kHz at 0.04% THD
380 Watts x 1 into 4 Ohms, 0.1% THD
Variable Lo-Pass/Hi-Pass filters (50-300 Hz)
Low Boost 0 - 10 dB at 40 Hz
High current MOSFET power supply
MOSFET output stage
Aluminum die-cast heat sink
One-sided terminal layout
Line-level and speaker level inputs
Dual mode capability
Gold-plated recessed connectors
Through outputs
Full Coverage and Details and Explantions
MOSFET Power Supply -- A power supply that employs MOSFET transistors to convert DC to AC. Offers superior thermal stability and more accurate switching.
MOSFET Output Stage -- An amplifier output stage that employs MOSFET transistors, offering superior thermal stability, faster switching, extended frequency range, and better transient response.
Dual mode -- An amplifier configuration in which both a stereo pair and mono speaker system are simultaneously powered by a stereo amplifier
Products and Specs
Circuit System -- OTL (output transformerless) circuit, pulse power supply
Inputs -- RCA pin jacks
Outputs -- Speaker terminals
Through out pin jacks
Speaker Impedance -- 2 - 8 Ohms (stereo)
4 - 8 Ohms (when used as a bridging amplifier)
Maximum outputs -- 300 W x 2 (at 4 Ohm)
760 W (monaural) (at 4 ohms)
Rated outputs (Supply voltage at 14.4V) -- 150 watts x 2 (20 Hz - 20 kHz, 0.04% THD, at 4 ohms)
190 watts x 2 (20 Hz - 20 kHz, 0.1% THD, at 2 ohms)
380 watts (monaural) (20 Hz - 20 kHz, 0.1% THD, at 4 ohms)
Frequency response -- 5 Hz - 50 kHz
Harmonic distortion -- 0.005% or less (at 1 kHz, 4 Ohm)
Input level adjustment range -- 0.2 - 6.0 V (RCA pin jacks)
0.4 - 12.0 V (High level inputs)
High-pass filter -- 50 - 300 Hz, -12dB/oct
Low-pass filter -- 50 - 300 Hz, -12dB/oct
Low Boost -- 0 - 10 dB (40 Hz)
Power supply voltage -- 10.5 - 16 V
Current Drain -- At rated output: 40 A (4 Ohms)
Remote input: 2 mA
Demensions
Approx. 14-1/8 x 2 x 10-1/2 in. (358 x 50 x 265 mm) (w/h/d) not including projecting parts and controls
Weight
Approx. 3.5 kg (7 lbs. 11 oz) not including accessories
SUBS
ID12V.2 D4
12"
250/500W
Dual 4 Ohms
11.5mm
0.85 cu.ft
1.5 cu.ft
gargsta
Northwest (Sales)
14
May 14, 2006 07:01 AM
rex_racer728
Audio / Security / Video
Feb 14, 2005 06:32 PM
