Clutches and Flywheels for 5th gen lude
Old Jun 5, 2006 | 06:02 AM
TeamObC408's Avatar
Default Clutches and Flywheels for 5th gen lude
whats a good overall normal everyday driving flywheel to purchase that wont mess up the tranny after a period of time...I've heard that if you get too light of a flywheel, it can mess up the tranny....not sure if thats true or not but I don't want a crazy one anyway..just something a little better than stock. also whats a good stage 1 clutch...thanx
Old Jun 5, 2006 | 07:10 AM
JDubsLoPro's Avatar
personally, I wouldn't go anything lighter than 12-13 pounds...it could mess with the balance of the crankshaft. But a good stage 1 would be exedy. That's what I run w/moderate mods and holds pretty well, good life so far. It's around 40% more holding than stock, feels like stock...
Old Jun 5, 2006 | 11:29 AM
petern101's Avatar
Default Re: (JDubsLoPro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDubsLoPro &raquo;</TD></TR><TR><TD CLASS="quote">personally, I wouldn't go anything lighter than 12-13 pounds...it could mess with the balance of the crankshaft. But a good stage 1 would be exedy. That's what I run w/moderate mods and holds pretty well, good life so far. It's around 40% more holding than stock, feels like stock...</TD></TR></TABLE>
wow. well your personal experience with flywheels is horrible. everything is alright info.
do you know how many preludes run 8lbs fidanza flywheels??? it won't mess up anything. the only thing i noticed was faster dropping rpms after shifting.
WON'T affect daily driving
if you want OP, just get a oem replacement or stage 1 xxxxxxxx and a lightweight flywheel.
Old Jun 9, 2006 | 11:30 AM
JDubsLoPro's Avatar
Default Re: (petern101)
absolutely correct, I've never driven a lude w/a light flywheel...but that was just my .02...
Old Jun 9, 2006 | 09:37 PM
piotrush's Avatar
Default Re: Clutches and Flywheels for 5th gen lude (nyluder)
I have the fidanza 8lb + exedy organic disk - clutch pedal feels like stock, revs are a bit more responsive as well, streetability is not a problem at all, just give it a bit more gas when starting up hill. My only complaint is that this particular setup chatters on my car...no one else with that setup that I know has that problem.
I like my 8lb, my room mate has a 12.2 cluchmaster fw and he loves his, thinking mine is way too light for his taste.
Old Jun 10, 2006 | 01:18 PM
Dameltajo's Avatar
Default Re: Clutches and Flywheels for 5th gen lude (piotrush)
8lbs fidanza + exedy oe owner... 1 year driving it... No problems at all...
just the quick drop of rpms.
Duck Sauce
May 18, 2008 10:43 AM
IgnitionZ05
Aug 21, 2007 05:24 PM
Inextricabledrvr
Mar 28, 2004 11:23 AM
InfamousRS
May 8, 2002 06:36 PM
-=TWITCH=-
Apr 17, 2002 08:25 AM
