FS: 1994 Integra LS/Vtec/NOS (SOCAL)
Old Jun 4, 2006 | 11:39 PM
specc's Avatar
Default FS: 1994 Integra LS/Vtec/NOS (SOCAL)
1994 Acura Integra
Has full GSR Gray Leather Interior ... 5speed trans with shortshifter... CD / MP3 player with 6 disc changer in glovebox ... spoon rims with brand new tires and coil overs. car is primered white and should be repainted but is in perfect running condition
B18b Block:
* OE Pistons
* OE Rods
* Knife Edged / Balanced Crank
* Lightened Flywheel
* Stage 3 Clutch
* Block Girdle
* Upgraded Oil Pump (12psi per 1000rpm)
* Upgraded Water Pump
B16A2 Head
* ITR Valve Train
* GSR Cams
* Skunk2 Adjustable Cam Gears
* Type R Ported / Polished Intake Manifold
* Ported Throttle Body
* Fully Ported / Polished with Valve Job
Transmission is a Type-R Hydro With LSD NO GRINDS NO PROBLEMS PERFECT
Misc
* MSD 6a Ignittion
* MSD NOS Window Switch
* NXpress Wet Nitrous Kit
* NXpress Purge Kit
The nitrous kit is setup foolproof .. i will explain how i have it setup so it CANT hurt anything !
3 points of activation ...
1st is a switch on the dash of course.. that turns on the Purge kit and turns on the microswitch that is on the throttle body ...
2nd the microswitch is set at WOT (wide open throttle) when the car is at WOT that microswitch is pressed and turns on the Window Switch
3rd The window switch is based off your cars RPM's .. mine for safety is set at 3800 and 6800 .. so it turns on the nitrous at 3800 and off at 6800 NO MATTER WHAT.. unless you change it
so in order for NOS to work you have to have the switch on .. be at WOT and in between 3800 and 6800 ... ANYTHING OTHER THEN THAT AND IT WILL NOT WORK AT ALL
the computer in there is a p28 chipped / socketed and has a chrome basemap tuned for that car and that setup ! Vtec at 5800 and Launch control at 3800 ...
Car DOES HAVE A SALVAGED TITLE but no major dents / dings and ZERO body / frame damage...
make offer or trader for EXTREMELY CLEAN INSIDE / OUT DAILY DRIVER
760 464 2430
Spec2323@yahoo.com
Kris
Old Jun 5, 2006 | 12:08 AM
ACLh22's Avatar
Default Re: FS: 1994 Integra LS/Vtec/NOS (specc)
GL with sale... here's a quick bump to the top... not like it needs it. GL with the sale!
TurBoTeG
May 18, 2007 07:10 PM
unix4linux
Dec 1, 2004 08:35 PM
coop94ls
Jun 16, 2002 09:24 PM
