J/L 12" w6v2 w/custom box and J/L 500/1 Mono AMP
Sub is enclosed in a custom ported box, this box is huge and will not fit in the ep but i thought ill try to see, maybe one of u can use it on another car, amp is mounted on top of the box 550 PICKED UP FOR EVERYTHING
more pics tomorrow
ill get the dimensions tomorrow when i find the damn tape measure.
just to show u how big the box is...
more pics tomorrow
Call me crazy, but wouldn't the vibration of the sub cause damage to the box-mounted amplifier? I'm almost certain it would, over time.
But hey....bump for a dope *** sub and equally dope amp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fEPst3r »</TD></TR><TR><TD CLASS="quote">im a noob when it comes to that, i guess u can say forhard but clean bass?</TD></TR></TABLE>
well, in that case you should know that used audio equipment is not worth much. but you are asking way to much for used stuff. your best bet it to post it up on ebay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Options »</TD></TR><TR><TD CLASS="quote">Call me crazy, but wouldn't the vibration of the sub cause damage to the box-mounted amplifier? I'm almost certain it would, over time.
</TD></TR></TABLE> when the sub is hitting, feel the box and notice how little it vibrates. now with that same volume feel other parts in the car. which vibrates more?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lDanny »</TD></TR><TR><TD CLASS="quote">that looks like a huge box for that sub</TD></TR></TABLE> the bigger the louder. Although this is only for ported boxes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XaznkewlguyX »</TD></TR><TR><TD CLASS="quote">
well, in that case you should know that used audio equipment is not worth much. but you are asking way to much for used stuff. your best bet it to post it up on ebay.</TD></TR></TABLE> JL audio carries on it's value used or new. check out on ebay how much these things go for. 550 isnt too bad.
</TD></TR></TABLE> when the sub is hitting, feel the box and notice how little it vibrates. now with that same volume feel other parts in the car. which vibrates more?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lDanny »</TD></TR><TR><TD CLASS="quote">that looks like a huge box for that sub</TD></TR></TABLE> the bigger the louder. Although this is only for ported boxes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER »</TD></TR><TR><TD CLASS="quote"> when the sub is hitting, feel the box and notice how little it vibrates. now with that same volume feel other parts in the car. which vibrates more?
JL audio carries on it's value used or new. check out on ebay how much these things go for. 550 isnt too bad.</TD></TR></TABLE>
Each sub has a optimal spec for the size of the box/air that you shoiuld use... and amps should not be mount on the box because it makes the box weak it you are pounding that sub... the sub could crack the box.
</TD></TR></TABLE> you have to be kidding me. there isn't much pressure inside that box, it's ported. How will it crack? Also get any sub meant for a small box and throw it in a big ported box, see how loud it'll get.
According to the JL spec sheet, it looks like the box made for that sub is within suggested spec for a ported application. Ported boxes are almost double the size of the suggested sealed box size for a particular sub.
And as far as mounting amps to sub boxes...I've never seen MDF crack in my whole life. I mean, even a 15" L7 in a box, with the amp mounted to the back of it, 2 years later is still hitting with no issues yet. I can see how maybe the solder points in the amp could loosen off, but the box cracking? I'd have to see it to believe it.
Regardless of opinion, good luck with the sale....priced pretty well if you ask me.
</TD></TR></TABLE>According to the JL spec sheet, it looks like the box made for that sub is within suggested spec for a ported application. Ported boxes are almost double the size of the suggested sealed box size for a particular sub.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fEPst3r »</TD></TR><TR><TD CLASS="quote">ahaha im such an audio noob compared to u guys. anyways sold it for 400 but was in need on money so what can u say.</TD></TR></TABLE>
NO ****** WAY! Holy ****, good deal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 »</TD></TR><TR><TD CLASS="quote">
NO ****** WAY! Holy ****, good deal.</TD></TR></TABLE> **** i would of bought it!
aquito
Aug 24, 2007 11:24 AM
CrazyModGSR
Audio / Security / Video
11
Dec 23, 2004 07:10 AM
