JDM zc axles and tranny.
Old Jun 4, 2006 | 07:54 PM
importsk8er's Avatar
Default JDM zc axles and tranny.
ok im doing the auto to manual conversion on my d16z6 95 coupe. and i have a zc tranny or atleast the guy said it was. he also gace me civic axles for it. i was told by a friend that those axles are nto the right ones....anyone know anytnign on this?!?!?! any help will be gretly appreciated. thanks...
Old Jun 5, 2006 | 08:05 AM
Default Re: JDM zc axles and tranny. (importsk8er)
bump.
Old Jun 5, 2006 | 08:14 AM
LowSlow93Sol's Avatar
Iv got a ZC Block and an SI transmission(sorta reversed from your question), but everything bolts up just fine. as far as fit and finish is concerned, you should have no problem using the ZC tranny and axels.
Whats the code on the front of the transmission...?
Old Jun 5, 2006 | 01:12 PM
Default Re: JDM zc axles and tranny. (onefast93sol)
ok sweet. yeah thanks alot for the replie.
edit: oops, on the tranny it says J8B then the barcode and under the bar code it says P20...!!?!
Old Jun 5, 2006 | 02:31 PM
schardbody's Avatar
if it is a zc tranny then the axles are differant. the drivers side will have an intermediate shaft because the zc uses equal lenght axles like a B series.
Old Jun 5, 2006 | 07:18 PM
Default Re: (schardbody)
so what are you saying?! my '92 civic si axles wont work?! the guy told me he ran the setup on his 5th gen hatch. does anyone know if the tranny is really a zc from that code i posted above?!?!
Old Jun 5, 2006 | 08:57 PM
schardbody's Avatar
nope, all zc trans are cable except the sohc zc vtec which is the same as a z6 tranny
Old Jun 5, 2006 | 10:14 PM
how do i tell if it is hydrolic or cable?! it has sensors and stuff on it....he told me it was hydrolic. would pics help?!?!
Old Jun 5, 2006 | 11:14 PM
FalkenSiR's Avatar
Default Re: (importsk8er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importsk8er &raquo;</TD></TR><TR><TD CLASS="quote">how do i tell if it is hydrolic or cable?! it has sensors and stuff on it....he told me it was hydrolic. would pics help?!?!</TD></TR></TABLE>
There's a nipple (like a caliper nipple) that you can bleed. Cable trannies have the fork sticking out.
Old Jun 5, 2006 | 11:32 PM
EGdrop6's Avatar
Default Re: (fast95eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">if it is a zc tranny then the axles are differant. the drivers side will have an intermediate shaft because the zc uses equal lenght axles like a B series.</TD></TR></TABLE>
so if i have a d15b with a stock cx tranny. couldnt i just use any d series axles cuz im about to change them.
Old Jun 6, 2006 | 08:38 AM
schardbody's Avatar
you say it says S20 so its hydro, therefore its not a zc tranny. use any 92-95 civic axles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGdrop6 &raquo;</TD></TR><TR><TD CLASS="quote">so if i have a d15b with a stock cx tranny. couldnt i just use any d series axles cuz im about to change them.</TD></TR></TABLE>
yes use any 92-95 civic axles.
Old Jun 6, 2006 | 09:49 AM
No! i said it said P20. Not S20. It looks liek someone wrote on another part of the tranny and it says LX...?!?!? hmmm. so anyone know what P20 is??!?!
Old Jun 6, 2006 | 10:34 AM
schardbody's Avatar
p20 is obd1 hydro tranny, doesnt mean anything else. its not a zc tranny though if it hydro, so dont worry, just use stock axles.
Old Jun 6, 2006 | 12:27 PM
ok thanks....crap i think its a lx tranny....do you think i will be fine for boost?!?!
Old Jun 6, 2006 | 01:28 PM
schardbody's Avatar
why LX, look by the fill plug, should see a circle w/ B000 or A000. B000 is good, EX/SI, A000 can be anything from vx/cx/lx/dx etc.
Old Jun 7, 2006 | 05:51 AM
Default Re: JDM zc axles and tranny. (schardbody)
if i ran a lz or dx tranny, woudl it be badd with my z6? especially when i go turbo?!?!
Old Jun 7, 2006 | 09:01 AM
schardbody's Avatar
not as good as ex but not as bad as cx/vx, so its in between in my opinion.
onefiine69
Mar 7, 2005 06:42 PM
blackZC (W)
Feb 16, 2004 09:38 PM
Aphrodavid
Nov 6, 2002 08:34 PM
OldSchoolCrxSiR
14
Jul 30, 2002 11:14 PM
rasta420
Apr 27, 2002 07:14 PM
