HELP! Bolt sticking out of engine block!!
Old Apr 15, 2002 | 07:49 AM
electronspeeder's Avatar
Default HELP! Bolt sticking out of engine block!!
I have a B16 (2000 Si) and I was changing my oil yesterday when I noticed something strange. When I took my oil filter off I noticed a bolt sticking out next to it about 1 1/2 inches. I believe it was a 12mm, and when I tried turning it in, it was really really seized.
What is that bolt? Should it be something I should be worried about?
Old Apr 15, 2002 | 07:50 AM
SCsol's Avatar
Default Re: HELP! Bolt sticking out of engine block!! (electronspeeder)
do you have a picture of the bolt or a diagram
Old Apr 15, 2002 | 07:59 AM
Default Re: HELP! Bolt sticking out of engine block!! (lowsol)
Umm... no picture now. I guess I could get one later... probably tonight or tomorrow.
Old Apr 15, 2002 | 08:44 AM
Trey's Avatar
25 Year Member
Here is a generic pic, which bolt?
*pic by Ausmith
Old Apr 15, 2002 | 09:09 AM
Default Re: HELP! Bolt sticking out of engine block!! (Trey)
I think it's the bolt immediately to the bottom right of the filter in that picture. Well, there's no bolt in that pic, but I mean the one that belongs in that hole.
Old Apr 15, 2002 | 09:29 AM
Plan B's Avatar
wouldn't that hold on that pain in the *** brace that connects the intake manifold and the block?
Old Apr 15, 2002 | 10:29 AM
Default Re: HELP! Bolt sticking out of engine block!! (Plan B)
Huh? That seems too far away to have any relevance.
Old Apr 15, 2002 | 10:49 AM
dchu's Avatar
Plan B is right. I remember looking through my friend's Si to compare hoses, etc. when I was taking off my jrsc and I saw this bolt sticking out under the filter. I put his car on ramps to check it and I think it was the manifold support bolt. If you look at it, the bolt has a washer welded in the middle to keep it from being screwed all the way in. I think honda did that so there is enough clearance to remove the bolt.
Old Apr 15, 2002 | 10:52 AM
Default Re: HELP! Bolt sticking out of engine block!! (dchu)
Wow. So you mean it's supposed to stick out like 1.5 inches? It just looks so wrong!
Old Apr 15, 2002 | 10:57 AM
Crazydave's Avatar
Check to see if you have the manifold brace on.. if no... then it's an extra bolt...
Old Apr 15, 2002 | 11:25 AM
civicguy's Avatar
Default Re: HELP! Bolt sticking out of engine block!! (Crazydave)
i think is the bolt that hold the halfshaft
Old Apr 15, 2002 | 03:28 PM
Default Re: HELP! Bolt sticking out of engine block!! (civicguy)
bump
Old Apr 15, 2002 | 04:27 PM
MaxBoost's Avatar
New User
ditto
Old Apr 15, 2002 | 04:31 PM
civicb18b's Avatar
oil filter boltthreadder thingy majigger?
Old Apr 15, 2002 | 07:19 PM
owen_the_soyboy's Avatar
Old Apr 15, 2002 | 07:34 PM
Kamin's Avatar
Default Re: HELP! Bolt sticking out of engine block!! (owen_the_soyboy)
dont just start loosening **** if you dont know what it does
lol
Old Apr 15, 2002 | 09:00 PM
So... it's supposed to be like that right?
EF'GSRrr91
Sep 2, 2014 06:18 PM
Koko4
16
Dec 25, 2013 05:42 PM
foodkeeper
May 8, 2012 12:19 AM
nguyen12600
Transmission & Drivetrain
Feb 24, 2012 10:02 AM
