Suspension Vibration
I recently changed out my passenger side axle. Since then I have had some vibration. It only happens when I am cruising/light load or when I am turning right at slower speeds. I have isolated the noise to the passenger side. I don't think it is the axle, the vibration does not change with speed. It sounds more like two metel pieces making contact. I had to take most of the suspension apart (almost the whole lower control arm except ball joint and the lower strut bolt) to get the axle on. I though it was the sway bar bushing so I sprayed that with lubricant which did not help. Do you think this could be the axle or the suspension. Where should I start?
Thanks.
Thanks.
