How to test an A/C Compression out of the car?
Old Jun 4, 2006 | 04:10 PM
92integraVTECgsr's Avatar
Default How to test an A/C Compression out of the car?
How can I test my AC Compressor while it is outta the car? It is just sitting in my room, and I want to put it back in, but not if it doesnt work. Is there any way to test it while it is out of the car?
Old Jun 4, 2006 | 04:34 PM
nitrofish420's Avatar
Default Re: How to test an A/C Compression out of the car? (92integraVTECgsr)
Not really. You can turn it by hand and make sure it turns smoothly and doesn't bind up, but you can't really test it's proper function or check for noises without mounting it up and charging the system.
Old Jun 4, 2006 | 04:45 PM
Default Re: How to test an A/C Compression out of the car? (nitrofish420)
well it worked great last summer, than one day it just started blowing warm air. then i took it out when i did and engine swap.
So would you think it just needed a recharge?
Old Jun 4, 2006 | 05:06 PM
Lack of charge is definately the most likely cause, but it could've been other problems too. Did it blast refrigerant out when you disconnected it?
Old Jun 4, 2006 | 05:41 PM
ya
Old Jun 5, 2006 | 04:43 PM
I guss that was a bad way of asking, as even slight pressure in the A/C system will make a hose blast off while disconnecting it... Really, without knowing the refrigerant pressures prior to removing the compressor, the only way to know will be to mount it up and try it out. Unless there's some kind of compressor dyno out there that I've never heard of. But if I were a betting man I'd say it's probably fine and was just low on refrigerant. I've only seen one or two bad Honda compressors in the 6 or so years I've been a tech. And one of those was because a compressor clutch fried and heated up enough to damage the snout of the compressor. The internals were probably fine. Just remember that if you or someone else is gonna use it, drain the oil out of it and refill with the proper amount of the correct oil.
Old Jun 5, 2006 | 05:06 PM
Yambor's Avatar
evacuate, vacuum down for 30, hold for 15 or 5..if doesnt hold there is a leak, when replacing the compressor, turn over and let oil drain out, the refil with proper amount of oil..
Old Jun 5, 2006 | 05:15 PM
Default Re: How to test an A/C Compression out of the car? (Yambor)
how do i convert to the r134a? I seen the r134a conversion kit forsale at autozone, and was just wondering how that works?
anyone do it?
Old Jun 5, 2006 | 05:16 PM
do i need to take it to a shop to have it vacummed? and how do i go about adding the proper oil? and what is the proper oil? thanks.
Old Jun 5, 2006 | 05:31 PM
Yambor's Avatar
you need PAG oil..
and id take it to a shop, do not retrofit yourself..
get it done professionaly
cryingsuns
Northern California
May 20, 2012 08:17 PM
dazcivic
Oct 25, 2011 02:09 PM
wildoutwhitegsr
Sep 7, 2010 01:19 PM
TurboJesse
Sep 16, 2003 03:14 PM
