help on my swap
got a 94 civix ex, and just got done putting a b20 on it, ots obd1, but it wont start......
the b20 was in a 92 integra, has a 92 manifold, gsr head and ls tranny.....
got 2 ecus one i think is form the 92 integra but its chipped and i got the p28...
an there is like two or three sensors that wont plug in....
wat colud be wrong
wat colud be wrong
Your should spend a little more time giving details and troubleshooting. If someone tried to tell you why your car wouldn't start @ this point they would be guessing.
You should start by seeing if your getting spark & fuel and then go from there.
ok.....
wanna know if my harness from my car would work on the engine, because it the motor was in a 92 integra, r do i need to use a ecu from a 94 and up???
whenever i tried to turn the car it feels like the timing belt is off,,,,
its myfirst time doing a swap and i dont know how to what are the common thing to look what is wrong.....
92 integra is OBD 1 and 94 is OBD 1 also so that should not be a problem.
Pull the spark plugs and crank it over and see if your getting fuel (you will smell it)
Next insert a plug into a plug wire, ground it by touching the metal part of the plug to a ground spot and crank it over and see it it sparks. If you have these too things it will make it much easier to troubleshoot.
