H22 and lot's of other stuff for sale!
CALL ME FOR FASTER SERVICE!!!!!!!!
Most of you should have free long distance calling!!!! 415-850-8866[/B]
!!!!!!!!!!!!!!!!!!!!!!!UPDATED!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!
Due to a lifestyle change I may have to sell parts of my racecar.
WILL NOT PART OUT BLOCK AND HEAD, WILL ON ONLY SELL THEM TOGETHER
H22 Long block fully built! NEVER BEEN RAN! 0 MILES
ARP Headstuds
Cometic Headgasket (.044 thick)
ACL Bearings
Balanced and polished crank
87mm Benson sleeved
Pauter Rods
CP 9:1 pistons
Balance shafts removed and plugged
OEM oil pump
OEM oil pan (used)
Fluidamper pulley
H22 Head (work done by Portflow)
H22 Valve Cover with -8 bungs welded on (used)
H22 intake manifold with IAB removed
H22 cams
AEM cam gears
Supertech valvetrain
Port and polish
Valve job
Brand new seals and gaskets
Turbo manifold,turbo and distributor not for sale. (Money does talk, though)
Have 44mm Tial with flange welded to manifold too(not shown
PM me for a price. SERIOUS Inquiries!!!!! This was built by EARL LASKEY and block machine work by Benson!
-12 Braided 6.5 ft. UNUSED/NEW $30 Shipped
NOS Bottle with Blow down $100 Local Pickup Only!
GSR 94 up P/S Pump $25 shipped
GSR P72 Dinan ECU[B]PENDING[B],1 Bar GM Map Sensor $25 Shipped
Integra 94-up Driver’s side mount $25 Shipped
AEM Accord Timing gear $25 Shipped
Civic Crank Pulley $25 Shipped
4ea –6 Straight $8 Shipped Ea!
1ea –6 Low Profile 90 Sold!!!
1ea - 90 Swivel seal $10 Shipped
1ea –6 90degree socketless $10 Shipped
1ea –6 straight socketless $8 shipped
Low Pressure NOS Non-bypass fuel regulator $30 Shipped
This ad will be constantly updated with more stuff!!!!!!!
All will be shipped unless specified to 48 US Continental states ONLY
Items are used unless specified new or unused
Paypal preferred(I will not charge you for the 3% charge) but will accept money orders, cashiers check.
money order/cashiers check must clear before items are mailed out.
Will not send out NOS bottle, even if you pay me a large amount of money. Not worth the hassle.
Modified by accordking at 8:48 PM 6/8/2006
Modified by accordking at 7:24 PM 6/12/2006
Modified by accordking at 7:25 PM 6/12/2006
Modified by accordking at 7:27 PM 6/12/2006
ARP Headstuds
ACL Bearings
87mm Benson sleeved
Pauter Rods
CP 9:1 pistons
OEM oil pump
OEM oil pan (used)
Fluidamper pulley
H22 cams
AEM cam gears
Port and polish
Valve job
