side skirt help
Old Jun 4, 2006 | 02:56 PM
DC5StylZ's Avatar
Default side skirt help
i have a stock ls i knw its bad enough lol but i have the black plastic skirts and i want them to mach my car "white" can i do this job myself or sould i get it done.. if so what paint sould i use.. or if any 1 has done it b4 how much does it usually cost thanx 1
Old Jun 4, 2006 | 03:00 PM
DC5StylZ's Avatar
Default Re: side skirt help (hondacuraLs)
can someone answer me
Old Jun 4, 2006 | 03:03 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
have you ever painted car parts before? It is really not too much, I believe people usually pay around 225 to get the sides and front lip painted(if you have a front lip). If you prep them yourself it will save you more money too.
Old Jun 4, 2006 | 03:22 PM
JDM-EJ1's Avatar
Default Re: side skirt help (BOLO-FTW.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOLO-FTW. &raquo;</TD></TR><TR><TD CLASS="quote">have you ever painted car parts before? It is really not too much, I believe people usually pay around 225 to get the sides and front lip painted(if you have a front lip). If you prep them yourself it will save you more money too.</TD></TR></TABLE>
If you can get the correct color paint and can spray paint you can do this yourself.
Old Jun 4, 2006 | 03:24 PM
Guess whos bizzack
Default Re: side skirt help (JDM-EJ1)
of course you CAN do it yourself, but you never know how its gonna turn out if you are not an experienced painter
Old Jun 4, 2006 | 03:42 PM
CleanLikeJdm's Avatar
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOLO-FTW. &raquo;</TD></TR><TR><TD CLASS="quote">of course you CAN do it yourself, but you never know how its gonna turn out if you are not an experienced painter</TD></TR></TABLE>
Lol.. if you can't rattlecan something .. I don't even know what to say ..
Old Jun 4, 2006 | 03:59 PM
phoshizzle88's Avatar
Default Re: side skirt help (FlatBlackTeg)
i just did mine. its pretty easy. but make sure you let them dry all the way before you put them back on. i had to redo mine cuz the paint wasnt completely dry and got fuckd up when i put them on.
Old Jun 4, 2006 | 04:03 PM
Guess whos bizzack
Default Re: side skirt help (phoshizzle88)
so where can you get spray paint for stock acura colors?
Old Jun 4, 2006 | 04:42 PM
daonei's Avatar
just go to an automotive paint shop and ask them to can your car's paint.
Your car paint/color code should be on the car when you open the door written between the door and the body.
Or you can just ask them for the code
Old Jun 4, 2006 | 04:49 PM
Guess whos bizzack
Default Re: side skirt help (daonei)
hum, i may try a can job on my lip to see how it turns out
Old Jun 4, 2006 | 05:15 PM
ProjeKt's Avatar
In Basic Training
I wouldn't trying to paint it yourself without knowledge of actually doing it before leads to dripping and horrible painting
Old Jun 4, 2006 | 05:16 PM
ProjeKt's Avatar
In Basic Training
Actually if you dont want to do it call up maaco they do paint for cheap
Old Jun 4, 2006 | 05:39 PM
DC2_2's Avatar
Default Re: side skirt help (ProjeKt)
If u do end up doing it yourself be sure to take them off . I messed up on mine by NOT doin that.
Old Jun 4, 2006 | 05:54 PM
Guess whos bizzack
Default Re: side skirt help (DC2_2)
haha thanks for the hint, I might try the front lip since its all messed up from being to low anyways
Old Jun 4, 2006 | 07:50 PM
Moogen Powah's Avatar
You could also try PaintScratch to get the color codes and/or paint.
Old Jun 4, 2006 | 11:11 PM
xXLiGhTsTyp3RXx's Avatar
i painted my own car.. so here'a some quick tip
1) sand the bitch down from rough to smooth
2) primer the bitch with even coats
3) Some quick Sanding
4) First coat.. (Even paint and light spray)
5) dry
6) second coat ( same as first coat but a little bit more harder on the thickness
7) dry
9) Last coat for good luck ( EVEN !! AND CLEAN COAT, CAUSE THIS Is the MOST IMPORTANT ONE!)
10) Dry
11) GLoss coat one ( light)
12)dry
13) gloss coat 2 ( a little more thicker coat)
14)dry
15) gloss coat 3 ( Thick and even coat Get that shine)
16) Dry!
17) DRY!
18) wash it and wax
you can buff it it you like to get it really shinny.. but yeah its pretty simple just takes time! lots of FU(kin Time!
Old Jun 5, 2006 | 05:54 AM
DC5StylZ's Avatar
Default Re: (xXLiGhTsTyp3RXx)
hey thanx bro thats def what ima going to try and if it dosent work ill get it done
Old Jun 7, 2006 | 12:30 AM
DC2_2's Avatar
Default Re: (hondacuraLs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xXLiGhTsTyp3RXx &raquo;</TD></TR><TR><TD CLASS="quote">i painted my own car.. so here'a some quick tip
5) dry
7) dry
10) Dry
12)dry
14)dry
16) Dry!
17) DRY!
18) wash it and wax
you can buff it it you like to get it really shinny.. but yeah its pretty simple just takes time! lots of FU(kin Time! </TD></TR></TABLE>
sounds jus perfect to me.. my uncle does paint jobs an sounds like u hit it on the head
Old Jun 7, 2006 | 02:16 AM
Leo C's Avatar
Night Owl
Default Re: (DC2_2)
make sure to get primer that bonds to plastic
Old Jun 7, 2006 | 04:18 AM
RedDawg's Avatar
painted mine myself also:
1.) take them off the car
2.) sand them down, wash, dry
3.) i put mine up on 2 saw horses
4.) 1 coat of some paint adhesive spray, helps paint to bind to the skirts
5.) 1 coat gray spray can primer
6.) 2-3 coats of car color
7.) 2-3 coats of gloss
8.) let it dry for at least an hour past when you think it's dry
9.) wash/wax/reinstall
i did it this way and they never chipped/flaked for the ~2 years i had the car. drove it through buffalo,ny winters too
Byaaah!
Paint and Body
Nov 16, 2007 05:07 PM
R Legend
Feb 28, 2005 12:47 PM
Si Arn
Aug 10, 2003 12:04 PM
dlm
Dec 16, 2002 06:42 AM
