Skunk high comp valves & Toda high comp pistons, will it work?
Does anyone know if you have clearance problems with Skunk 2 high compresion valves in a K20A with a Toda 2150 Stroker kit (87.00 x 90.7mm) and the Engine kit (N2 camshaft & vlave springs)? So do you think the dome weight on the high compression pistons and the extra lift from the camshaft would cause the valves to hit?
powerfulperformance
Aug 27, 2001 04:36 AM
