Auto --> Manual Conversion: Clutch Switch Help
Old Jun 4, 2006 | 01:14 PM
itralex's Avatar
Default Auto --> Manual Conversion: Clutch Switch Help
I did a search for "Clutch Switch" and came up with threads on how to remove it.
well, i recently just swapped a set of automatic pedals for the manual pedal set in my crx because i am waiting to do a B16 swap in it. the pedal set went in with ease thanks to the instructions givin by "DaX"
well, now here is the questions. I notice that the pedal set i have swapped in has the clutch switch with the wires hacked off of it. I am wondering will the car start without the clutch switch wired up? and if it won't, how do i wire it up that it will?
so yeah, I'm just looking for some help from people who has done this conversion
The car is 1990 CRX HF, I will be using the ECU that came with my JDM B16 Swap.
Thanks!
Old Jun 4, 2006 | 01:16 PM
crx_88_si's Avatar
if the car was originally an automatic there will be no wires, instead those wires are where the shifter for the auto tranny is as a park/neutral switch.
Old Jun 4, 2006 | 01:18 PM
itralex's Avatar
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">if the car was originally an automatic there will be no wires, instead those wires are where the shifter for the auto tranny is as a park/neutral switch.</TD></TR></TABLE>
Thanks, so without the clutch switch the car will still start?
I am wondering will the car still start if I swap the ecu? the ecu i am using is a Manual transmission ecu.
thanks!
Old Jun 4, 2006 | 01:22 PM
beerex's Avatar
Default Re: (itralex)
The car won't start unless you tie the wires from the park, N.S.S. to your clutch switch or tie them together.
Old Jun 4, 2006 | 01:26 PM
itralex's Avatar
Default Re: (beerex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerex &raquo;</TD></TR><TR><TD CLASS="quote">The car won't start unless you tie the wires from the park, N.S.S. to your clutch switch or tie them together. </TD></TR></TABLE>
so i can just jump the 2 wires from the N.S.S together and i'll be good to go?
Thanks!
ilikejesus
May 7, 2009 08:46 PM
JokerX-1.6T
Jun 8, 2007 05:08 PM
helmet_mobn
Jun 15, 2006 04:37 PM
Jmunk
19
Feb 25, 2006 12:42 PM
Py7h0n
Mar 13, 2005 09:27 PM
