Cams for B16a
Old Jun 4, 2006 | 01:02 PM
broketuner-Sol_Si's Avatar
Default Cams for B16a
I found a good deal on a '00 ITR intake cam and the guy can also hook me up with a '98 JDM GSR cam. I was wondering if that would be a good combo for a realtively mild b16(stock block, no head work....for now ) . I've read many conflicting things about the gsr cams, such as they are nearly the same to a b16 or that they are close to an ITR exhaust cam. I know I could get better gains from afermarket cams (such as the buddy club spec 3 +) but I can get an excellent deal on these cams so I thought I should ask about this combo.
If it helps here's the mods to the motor(so far)
Injen CAI(3")
AEBS 70->68mm TB
AEBS ported IM
Magnacore wires and denso plugs
all stock internals
DC JDM style 4-1 header
custom 2.5" mandrel exhaust
Exedy clutch and flywheel
Old Jun 4, 2006 | 01:13 PM
the DOT's Avatar
b16a and gsr exhaust cams are allmost the same the gsr intake cam is a lil more agressive than a b16a intake cam ,i think that if your getting a good deal youll be happy but i would rather have both itr cams
Old Jun 4, 2006 | 01:15 PM
Default Re: (the DOT)
But the with the ITR cam on the intake side and GSR on the exhaust side would it be a good match?
Old Jun 4, 2006 | 02:37 PM
the DOT's Avatar
yes it will work fine ,it would just be better with the higher lift longer duration itr cam
my b16 has never been dynoed but it runs fine all the way up till the rev limmiter stops the fun at 8200rpm and it stills feels as though theres more there ,im running a gsr intake and a b16 exhaust
Old Jun 4, 2006 | 08:21 PM
hmm... any other opinions
Old Jun 5, 2006 | 09:24 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: (broketuner-egb16a)
You wouldn't happen to have a dyno sheet of your motor, would you?
Old Jun 5, 2006 | 10:08 AM
StRoKeD-B16bEj2's Avatar
Default Re: (black_EM1)
i can sell u my CTR cams for 275 for that setup
Old Jun 5, 2006 | 10:15 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: Cams for B16a (broketuner-egb16a)
I'm not a fan of CTRs really. Maybe because my butt dyno is really pessimistic .
How much are you getting them for exactly?
Old Jun 5, 2006 | 10:45 AM
Default Re: Cams for B16a (SkoundrelUSA)
IF I get them it would be 200 (150 for the ITR intake & 50 for the gsr exhaust)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrOjEcT Ej2 &raquo;</TD></TR><TR><TD CLASS="quote">i can sell u my CTR cams for 275 for that setup</TD></TR></TABLE>
I was told ITRs make more power over the CTRs, but that's a good price if it's both cams....I'll think about it if this guy doesn't come through.
Old Jun 5, 2006 | 10:55 AM
cute little bastard
OT but
Pretty sure if anything you'd be better off with CTRs, because CTRs and 00-01 ITRs are the same lift/duration/specs, but if you get a 97-99 ITR cam its not as aggressive as the CTR/00-01 ITR.
Old Jun 5, 2006 | 11:24 AM
CTR Cams = Best OEM Cams
Old Jun 5, 2006 | 11:39 AM
Phatch99's Avatar
Default Re: Cams for B16a (PrOjEcT Ej2)
well if u don't get that itr cam let me know i will pick it up.... but yeah i don't think u need to get the gsr exhaust cam your b16 one will do...
Old Jun 5, 2006 | 01:52 PM
the DOT's Avatar
theres only a 3degree more duration on the itr/ctr cams not a huge differance from the 97-99 itr cams but i do hear that they make more power
Old Jun 5, 2006 | 09:54 PM
so itr&gt;ctr? or the other way around?
Old Jun 5, 2006 | 10:25 PM
CTR is a lil better than ITR cam wise
Old Jun 6, 2006 | 07:37 AM
the DOT's Avatar
2000+itr is the same as ctr thats why they call them itr/ctr cams, 97-99 itr cams have a lil less duration than the 2000+ cams
lonely_driver4
10
May 27, 2019 06:54 AM
the.hamburglar
May 15, 2006 04:49 PM
unclepowers
Sep 23, 2005 10:27 AM
ferio 95
Jan 26, 2005 06:43 AM
ULTRA911
Nov 6, 2002 06:04 PM
