WAT IS THIS
Old Jun 4, 2006 | 11:13 AM
BlUAc's Avatar
Default WAT IS THIS
I konw there is the waste gate on the left but what is the other actuatior on the right do this is off of a old 91 volvo and has the mitsubishi sign on the wg and the other actuatior so what is it purpose and how to hook it up
Old Jun 4, 2006 | 01:20 PM
coneheadsracing's Avatar
Default Re: WAT IS THIS (BlUAc)
blow off valve maybe, got any bigger pics?
Old Jun 4, 2006 | 02:09 PM
D-meet07's Avatar
Default Re: WAT IS THIS (coneheadsracing)
yeah thats what it looks like.
Old Jun 4, 2006 | 02:35 PM
RACEPAK's Avatar
Default Re: WAT IS THIS (D-meet07)
bov
Old Jun 4, 2006 | 04:08 PM
Got_soy's Avatar
Default Re: WAT IS THIS (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">bov</TD></TR></TABLE>
Old Jun 4, 2006 | 04:58 PM
Bailhatch's Avatar
Default Re: WAT IS THIS (Got_soy)
yup
Old Jun 4, 2006 | 10:44 PM
BlUAc's Avatar
Default Re: WAT IS THIS (Bailhatch)
blow off valve huh thats wat I thought at first
this is what it looks like close up
this is the opening of the compressor where it sucks see on the bottom small opening
this is where it blows notice it on the opening on the top, the actuatior opens up in between to bypass the air from sucking in and going in the outlet of the compressor
this is just the other side of it see no opening to release pressure I can suck on that nipple like vacume and it opens up pretty easy
Old Jun 4, 2006 | 11:00 PM
k24em2's Avatar
Yea its a recirculating BOV thats built into the turbo.
Old Jun 4, 2006 | 11:06 PM
yee SERIOUS's Avatar
Default Re: WAT IS THIS (k24em2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">Yea its a recirculating BOV thats built into the turbo.</TD></TR></TABLE>
kinda cool. hahaha. i wonder if it could melt. lol
Old Jun 4, 2006 | 11:46 PM
BlUAc's Avatar
Default Re: WAT IS THIS (undercoverdc2)
I dont see on way to adjust it so I dont know what it is set at and do I just hook it to a vacume line
also this shaft has threads on the wg for adjustment but for what to adjust
Old Jun 4, 2006 | 11:50 PM
PhantomX's Avatar
thatz crazy.... i never seen that before haha
Old Jun 5, 2006 | 06:59 AM
RACEPAK's Avatar
Default Re: WAT IS THIS (PhantomX)
volvo turbo's have them too.
Old Jun 5, 2006 | 08:05 AM
BlUAc's Avatar
crazy I dont have to hook it up right I can just buy a regular one ryt
Old Jun 6, 2006 | 11:21 PM
BlUAc's Avatar
a couple of replys up I had asked about what are these threads for to adjust boost thats what im thinking
Old Jun 7, 2006 | 05:17 AM
Got_soy's Avatar
kinda, you dont have much adjustment with an interal gate wiht out a mbc
Old Jun 7, 2006 | 05:45 AM
under_psi's Avatar
a lot of volvo guys buy a block off plate for the recirculation/bypass valve and then run a BOV on the charge piping.
Old Jun 7, 2006 | 07:46 AM
BlUAc's Avatar
Default Re: WAT IS THIS (under_psi)
I have a turbo xs mbc but I dont wish to raise boost wg is set at 7lbs so im going to have to live with it was only wanting 5lbs and where can I find that block off plate because I also already bought a bov
Old Jun 10, 2006 | 05:58 AM
under_psi's Avatar
block off plate for your turbo....
http://www.kaplhenke.com/index.php?pg=15g
Old Jun 13, 2006 | 11:41 PM
BlUAc's Avatar
one more thing guys it is water and oil cooled how do I know which is which and do I need to have it water cooled or ya thanks alot
Old Jun 14, 2006 | 02:07 AM
RACEPAK's Avatar
the bigger holes are ususly for water....
Old Jun 14, 2006 | 06:35 AM
.RTErnie's Avatar
the srt-4 has an identical system.
Old Jun 14, 2006 | 08:29 AM
BlUAc's Avatar
Default Re: WAT IS THIS (~RTErnie~)
and what about needing the water lines
Old Jun 16, 2006 | 08:40 AM
BlUAc's Avatar
I cant really tell they are both all the same size do I need the water lines
Old Jun 16, 2006 | 09:27 AM
Got_soy's Avatar
you dont need water lines but its kinda preferred. if you do use them make sure your cooling system can handle the extra heat
JDM90CB7
Sep 15, 2008 04:21 AM
tylerpopley
Oct 24, 2007 02:23 PM
RACEPAK
Oct 20, 2007 04:34 PM
Slowass2dr
Apr 9, 2007 05:13 AM
TylerH
Mar 11, 2005 08:41 AM
