03 acura tl amp location?
Old Jun 4, 2006 | 09:52 AM
igo4bmx's Avatar
Default 03 acura tl amp location?
Hey guys-
I recently installed an aftermarket HU in a friend's 03 acura tl.
I didn't realize until we were done that there was a factory subwoofer, and it would not be powered!
realizing his non-navi bose system must have an amp, i'm wondering where it's located, and also wondering if it accepts rca level type inputs at all?
I might just replace it with an aftermarket amp.
Thanks for the help!
Old Jun 4, 2006 | 07:13 PM
fcm's Avatar
fcm
Old Fart
Default Re: 03 acura tl amp location? (igo4bmx)
It will not accept RCAs, not sure where it's mounted in a TL, have you checked the rear deck, [under side]. 94
Old Jun 4, 2006 | 07:51 PM
STK B16's Avatar
The factory Amp is in the Passenger Kick panel.. once u open it up. u will see it right away.. ...
there is no RCA input on it at all.
if you added a aftmarket unit... Im guessingyou are bypassing the amp..
Front left speaker wire is + blue/greeen and - is gray/black
Front Right speaker wire is + red/green and - is brown/black
Rear Left speaker wire is Blue/yellow and - is gray/white
Rear Right Speaker wire is + red/yellow and - is brown/white
I have worked on alot of these TL.. let me know if i can be further help
Old Jun 5, 2006 | 04:37 AM
igo4bmx's Avatar
Default Re: 03 acura tl amp location? (STK B16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STK B16 &raquo;</TD></TR><TR><TD CLASS="quote">The factory Amp is in the Passenger Kick panel.. once u open it up. u will see it right away.. ...
I have worked on alot of these TL.. let me know if i can be further help</TD></TR></TABLE>
I already have the headunit running on the speakers, but need the sub to work.
Old Jun 5, 2006 | 07:42 AM
STK B16's Avatar
ok what u need to do is... go to the Factory amp... and locate the Sub wires.. If i remember correctly its black and yellow... but best to test it .. usually its all with the speaker out..
gunsnbam
Audio / Security / Video
Feb 14, 2010 08:15 AM
BAZ
12
Sep 3, 2008 11:36 PM
97civicB18C
15
Mar 5, 2007 10:19 AM
IdotheSHOCKER
Jul 4, 2002 12:08 PM
